  1. don2222
    don2222
    Salem NH
    That is where I got this Quad, 1st one on FB MP :)
    bogieb, IHATEPROPANE and wildwest like this.
  2. don2222
    don2222
    Salem NH
    I am not a fan of screw terminals, the wires sometimes pull off and connecting and disconnecting takes time. So nice round lugs and insulated quick disconnects is one way to go?
    Then for testing, I can pull the wires off the T-Stat and clip them together for manual operation:)
  3. Pete Zahria
    Pete Zahria
    New Hampster
    I check it every day, multiple times, it changes so often..
    By the same token... you see plenty of people asking
    the most ridiculous prices for 'junk'.. laughable.
    Dan
    ivanhoe, imacman, savemoney and 3 others like this.
  4. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Got in the shop at first light...
    Ripped Munchy apart and got the rotor in the lathe (Hopefully for the last time)
    I had tightened the set screws on the bearings and the resulting "nerf" left by the set screw resulted in a bit of a tussle on one bearing getting it off the shaft..
    I finished the cut on the impact bars and then tossed the rotor in the mill and made small cuts where the set screws sit to prevent.
    Ended up cutting .080" off the bars which really got us in the sweet spot.
    Reassembled the unit and gave it a go.
    Looks great.
    Need to build the belt guard now.
    Weather is pretty good today, so the plan is to give munchy a proper shakedown.
    ivanhoe, savemoney, badbob and 2 others like this.
  5. wildwest
    Hi Pelletheads,
    My new washer works great! It's tall and I am not, detergent and bleach dispenser is awkward to begin with but it's also eye level on me and I keep dribbling bleach. I have one of these almost empty, any reason I couldn't rinse it out well and put bleach in it?
    CloroxToilet Bowl Cleaner Clinging Bleach Gel Cool Wave Scent 24 oz
    ivanhoe, imacman, badbob and 2 others like this.
  6. bogieb
    You just want to make sure that it is well cleaned out.
    You could also use a small measuring cup.
    ivanhoe, imacman and IHATEPROPANE like this.
  7. bogieb
    Had snow/sleet/freezing rain turning to rain 3 out of the last 4 days. I get 6 miles from home this afternoon and it starts with the white chit. It's sticking and the road is getting slushy.
    My fault - I had the snow tires removed last Friday and the forecast for a nice clear week coming up mysteriously turned to this cr*p.
    savemoney, ivanhoe, imacman and 3 others like this.
  8. don2222
    don2222
    Salem NH
    Wow BogieB, out in the hills and boroughs of western NH (Hillsboro NH LOL) you have more slushy snow than we do in south Salem NH next to Mass! But actually a good day to work in the shop testing out the 25-PDVC & Quad CB1200 I am refurbishing. :)
  9. will711
    will711
    Pocono Mts.
    3814AB62-0A25-47A5-B85D-B6856C425071.jpeg Had a hail storm here earlier with thunder and lightening
    savemoney, bogieb, ivanhoe and 5 others like this.
  10. gbreda
    gbreda
    NH
    Rte 11 in Farmington on the way home from work an hour ago
    savemoney, schoondog, bogieb and 7 others like this.
  11. badbob
    badbob
    Rain last 2 days,some light snow,but tomorrows storm started about an hour ago,wet heavy snow,about 2" already.Ah,life in the mountains.
    bogieb, ivanhoe, imacman and 2 others like this.
  12. gbreda
    gbreda
    NH
    almost 70 degrees here 2 days ago :loco: :crazy:
  13. badbob
    badbob
    lol yea but this is normal this time of year.Seems we always get a blizzard right around my birthday.
    savemoney, bogieb, ivanhoe and 4 others like this.
  14. gbreda
    gbreda
    NH
    Normal here too
    Winter appears to be shifting a bit. Stays warmer later into October and colder later into April
    IHATEPROPANE, bogieb, ivanhoe and 4 others like this.
  15. badbob
    badbob
    Kinda here also,same length of time,but,used to hunt elk off a snowmobile,to get up the mountain,but can use atv now.
  16. wildwest
    Quite warm here a couple days, snow storm tomorrow night.
    IHATEPROPANE, bogieb, ivanhoe and 3 others like this.
  17. savemoney
    I used to have a bandsaw that has been passed down from my grandfather. It was powered by a motor similar to yours. set up was different. The motor was attached on a hinged plate on the rear of the table. The weight of the motor determined the tension on the wheel. Favorite motors came off the old style washing machines. Just lift up on the hinged plate with the motor and then slip on the belt. Lower the motor and the tension was set. That set up was dependable for many many years. My son now has the saw.
  18. Earl764
    Earl764
    CT
    I’ve got 7 bags left. Hoping to use them up.
    IHATEPROPANE, bogieb, ivanhoe and 2 others like this.
  19. badbob
    badbob
    Why?I have about 2 tons left,could quit burning today and be very happy.But,as it is snowing heavily,do not see that happening.
  20. savemoney
    That looks like a decent stove. Hope you are able to recover your cost and make some buck in the process.
