  1. Eric VW
    Good point for sure, and I had considered the same thing.
    Guess they’d go to the hoard of 5 or so bags I have left...:whistle:
    Of course, since the VDub Cave is so inviting (basement with wood stove), we only ran the pellet stove a handful of times back in the fall....
    CleanFire, gbreda, ivanhoe and 2 others like this.
  2. will711
    will711
    Pocono Mts.
    It's nice to have options :thumbs:
    CleanFire, gbreda, ttdberg and 4 others like this.
  3. Eric VW
    Indeed!
    :yes:
  4. ttdberg
    ttdberg Pellet Pig
    CT
    Added a little to the stash this weekend - picked up a 60-pack of these AWFs. Really liking them a lot.
    :dancer:
    Luneyburg, CleanFire, gbreda and 7 others like this.
  5. slvrblkk
    slvrblkk
    Northampton, PA
    :vulture:
    Luneyburg, CleanFire, gbreda and 5 others like this.
  6. peterfield
    peterfield
    One of my favorite. Can’t find them up here.
    CleanFire, gbreda, ivanhoe and 4 others like this.
  7. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    The time has come to finish the new controller on the Big Whitfield.
    The room air fan control has taken a goofy twist and the fan makes weird noises when it starts up now.
    The control board triac is giving up....
    Decided to finish the new box.
    I drew up a complete updated schematic on a large poster sized sheet and finished ordering the last components.
    I mounted the box on a makeshift mount in my office so I can sit and work on it.
    I had done testing on the design before this and it worked, but changed some stuff to make things better.
    Got all the relays and timers mounted except one DPDT cube relay that starts the fans at full voltage and then reverts to controlled speed after 20 seconds.
    Fitted the main control cable and that's about it for today.
    The one DPDT cube is in transit, and will be here in a few days.
    I had the 11 pin octal plug base to mount it with.
    Getting the schematic complete, checking and rechecking it and then numbering all the wires as well as transcribing it all complete on paper as to what and where each wire ## goes and does in a "TEXT FORMAT" took a couple days.. MY HEAD HURTS
    Fully variable fan speed controllers with panel mounted meters and pots.
    Fans start at 120 volts and after 20 seconds will revert to presets.
    Volt meters read 0-150 volts
    Indicator lamps to indicate system power on, auger feeding, draft fan on, room air fan on, power to auger timer and low limit snap switch closed (stove up to temp)
    THIS THING IS A BEAST...
  8. IHATEPROPANE
    IHATEPROPANE
    Often I come to this site and realize how much smarter a lot of the folks on here are than me.
    This is one of those times.
    Nice work Snowy!
  9. Eric VW
    Yep! Me too...
    Awesome work Snowy Rivers :thumbs:
    CleanFire, gbreda, bogieb and 4 others like this.
  10. subsailor
    subsailor
    Winthrop, Maine
    X3
    CleanFire, bogieb, ivanhoe and 3 others like this.
  11. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Thank you folks for the :yes:
    Actually I am not a super brain by any means.
    I just graphed out what I needed to accomplish and then set about putting together a plan of how to get it done.
    A pellet stove is pretty simple if you think about it.
    A fire with the means to add fuel on a controlled basis and a fan to blow the heat around.
    That may be a tad over simplified.... but pretty close.
    Safety devices are certainly in the plan too.
    I added a few more safeties over and above what the factory had.
    Added a pressure switch into the convection plenum to shut off the fuel feed if the fan quits.
    Added a vacuum switch to the fire box before the draft fan to shut the fuel feed off if the draft fan quits.
    All the original safeties are retained in working order.
    Basic electrical principles are followed.
    All industrial quality relays and timers rated at 120 volt 10 amps.
    Certainly not gonna win a beauty prize for aesthetics, but it will gitterdone when its cold and going sideways....
    CleanFire, bogieb, ivanhoe and 4 others like this.
  12. badbob
    badbob
    LOL,actually your testing and experiments are awsome.There has been people wanting more info,about your old stove controller,on the "other" site,I do not comment.Actually,the "other" site,has had a huge influx of ignorant people,this year,they buy a 900 dollar stove,expect it to heat their huge house,and complaine when they have problems.Maybe I am just too old,but what happened to "RTFM"?lol. They way you have made your stoves work so well,on shells,people should be thanking you for years.
  13. badbob
    badbob
    OK,over 5 hours in backhoe,opening up rich part time neighbors road,95% done,broke a chain,easier to drive it home at very slow speed,instead of trying to drop it,and throw 200lbs in the bucket.Have to call the out of state neighbor to pay this bill,as,their neighbor refuses to pay,it is their road,tomorrow should be interesting.Left leg hurts from running the brakes,wind blowing 45mph,a crappy afternoon.I am home,fed cat,got a brew,life is still good.
  14. gbreda
    gbreda
    NH
    On Saturday I switched from Crabbe to 802's and had the same experience. At this time of year I am always in stove temp mode but with the 802 pellets I was not getting much of a big flame and even the flame i had went way down rather quickly.
    Crabbe are good for the price but there are definitely better pellets there in terms of ash color and volume. Heat is good enough for heating the home but the top shelf pellets that are 25+ more per ton have their advantages in all areas.
  15. gbreda
    gbreda
    NH
    Forget the cake, try the brownies :smoke: :whistle:
    subsailor, bogieb, CleanFire and 2 others like this.
  16. gbreda
    gbreda
    NH
    I'll meet ya and split em...bring will711 always need a lookout as well as an extra set of hands to load the stash
    bogieb, will711, CleanFire and 4 others like this.
  17. gbreda
    gbreda
    NH
    X2 !!!
    make that X3
    dammit, X4 :rofl: :lol:
    badbob, bogieb, CleanFire and 2 others like this.
  18. slvrblkk
    slvrblkk
    Northampton, PA
    He's always up for a road trip!
  19. ivanhoe
    ivanhoe
    Northern Ontario
    -29*F or even lower as the Acurite weather station seems to be frozen and not giving accurate weather report. Good thing I've check the princess's plug-in timer 'cause it was tripped :doh:
    I reset'ed and still no power, WTF! Further inspection, this is what I found :faint:
    edit; princess told me it's -38*F just up the road:shiver::shiver::shiver::shiver::shiver::shiver::shiver::shiver::shiver::shiver:
    badbob, Ambient, Luneyburg and 4 others like this.
  20. ivanhoe
    ivanhoe
    Northern Ontario
    When Snowy Rivers post something, we take notice :binoculars:
    She never seizes to amaze us with her skills and talents :thumbs:
    They're others who shine as well so don't discredit yourself :yes:
    We all have our strength's and weakness's :whistle:
    But as a group, we all shine together :beerbbq:
    badbob, Ambient, Luneyburg and 3 others like this.
