  1. bogieb
    Great if you can find non-alcohol fuel of any type. Unfortunately don't have any around here unless I buy it by the 32 oz can (or smaller) :(
  2. Pete Zahria
    Pete Zahria
    New Hampster
    Correct.... closest one to me is like 40 minutes away..... if they still carry it.
    Dan
    ivanhoe, jtakeman, CleanFire and 4 others like this.
  3. savemoney
    True, I'll get over it when daylight is here until at least 7:30 PM. In the mean time, I'm like the water spinning around and around lower and lower in your toilet.
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Don't talk about toilets, I had get a snake yesterday as my plunger didn't do the job.
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Tamed my high electric use lights in the up/down stairs hallway by replacing 96 watt incandescent +39 watt cfl's with 12 watt +27 watt led lights .
    ivanhoe, jtakeman, CleanFire and 5 others like this.
  6. Earl764
    Earl764
    CT
    I still have some cfls from a batch i bought in 2005. Will replace as they burn out with leds.
    They have some leds now that look exactly like older style fancy incandescents.
    Anyone ever have to do the trick of keeping an incandescent on during the winter in a crawl space or somewhere with vulnerable pipes?
    savemoney, ivanhoe, jtakeman and 6 others like this.
  7. IHATEPROPANE
    IHATEPROPANE
    Where would you get the 93 octane ethanol free gas?
    ivanhoe, jtakeman, CleanFire and 3 others like this.
  8. IHATEPROPANE
    IHATEPROPANE
    I have some for my crawlspace
    ivanhoe, jtakeman, CleanFire and 2 others like this.
  9. IHATEPROPANE
    IHATEPROPANE
    Replaced the gasket on the EP. Ran the genny for a couple hours to get it some exercise. Then did an oil change.
    Still need to do the oil in the ChitBlower and do leaf cleanup. That will happen if it ever dries out.
    savemoney, ivanhoe, CleanFire and 4 others like this.
  10. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Ahhhhh
    That could be an issue.
    We have a card lock (Been with them since 1991 when I started trucking) and their premium is the Alky free stuff.
    I use it in all the small engines.
    Buying it by the small can is not cost effective for sure.
    If all you have is Alky laced fuel there is a way to fix that....
    Use a clear 1 gallon jug, add the gasoline, add a quart of water, slosh well to mix the fuel with the water...LET SIT UNTIL SEPARATED FULLY (The alcohol binds with the water and settles to the bottom)
    Drain off the water/alky mixture and whats left is alcohol free fuel.
    A bit of an extra task, but it is far less expensive than the the repairs to small engine parts that are ruined by the alcohol laced fuel.
    Just need to be careful to get the water/alky mixture out of your jug before using the fuel.
  11. imacman
    imacman
    Denver, NC
    Earl764 , are they water or heat pipes, or both? I did have an issue with a frozen attic heat pipe for a short while at my last house on an exposed heat pipe....tried light bulb (that didn't work very well in that situation), and then heat tape. Got smart after that and installed a ThermGuard on that zone......no more worries.
    At my present shack, the incoming water line is outside (above ground, if you can believe that :loco: :crazy:), and has to be insulated and has to have a heat tape installed....this is the one I use:
  12. Pete Zahria
    Pete Zahria
    New Hampster
    LED... only way to go... brighter, and instant on compared to CFL. Once I got a couple,
    I bit the bullet and replaced all the CFL's... gave them away...
    My cousin rents out a couple of mobile homes... he has them in an enclosure around the water pipes...
    They work ok.. until it gets REAL cold... or if the bulb burns out!!
    :faint:
    Dan
  13. CleanFire
    CleanFire
    Multiple times Earl, during the Ice storms of '98 and '08. In the crawlspace, and on a drop light, lowered inside the well cap. And once back when we first moved here back in ('93) after finding out the well water pipe was only buried 2' underground, in spots. :headbang: Got that fixed PDQ the following spring, a new line buried 4' with blue board insulation boxed all around / on top of the run. ... I got good at trench Digging that spring. :D
    Don't really use the Incandescent bulbs anymore.. we just leave the bathroom faucet cold water line on 'trickle', to let the well pump cycle every 20 mins. or so, during extended (-) cold weather.
    Tried heat tape on the pipes once waay back, lasted a few years, before failing. Not a fan of Heat Tape - house further up in the Development caught fire, because of one that shorted - according to the Fire Dept. :eek: Haven't used it since, after hearing that.
  14. Luneyburg
    Luneyburg
    Hills of Central Mass
    Today Church this morning and then This pictured below. Ahhh Yeaaahh reading the entire Pellet shortage thread probably not a good idea for me but I did so just going to have to be careful. Beautiful day today with the exception of the brisk wind nice and Sunny for a change wish I could be doing some yard work but not yet and heck its far to windy out anyways.
    Great day to everyone and a special thanks to all our Vet's !
    ivanhoe, IHATEPROPANE, bogieb and 6 others like this.
  15. Earl764
    Earl764
    CT
    I’ve seen it for both. That is nuts about your water service. I’ve see that in San Francisco and it made sense there, but not up here.
  16. imacman
    imacman
    Denver, NC
    The one I listed was the same one I replaced.....the old one had 5-6 years on it, and worked perfectly (no problem last winter during the 2 week Arctic blast we got), but I didn't want to chance it.....the park Mgr. agreed it was time to replace.
  17. imacman
    imacman
    Denver, NC
    Well, it was a gorgeous day out, not too cold (wind wasn't too bad), so I decided it was time to wrap things up for winter:
    • cleaned all the leaves from around house/bushes/lawn, all blown into the woods ✓
    • hose drained, put away, insulation cap over hosebib ✓
    • plugged in water line heat tape ✓
    • brought sn*wblower to front of little shed, checked gas ✓
    I'm done. Time for some racing on TV, and some :coldone:, and :stirpot:
    Oh, and propane tanks got filled yesterday. This year's price is up about $.30/gal........$2.29 :emptywallet: Hoping for a warm-ish winter.
    ivanhoe, jtakeman, bogieb and 2 others like this.
  18. imacman
    imacman
    Denver, NC
    And a big THANK YOU to all the Veterans, on this forum, across the USA, and around the world. You kept us safe, you're the best!
    :handshake: :salute:
    ivanhoe, CleanFire, jtakeman and 4 others like this.
  19. artc
    artc
    Rocky Hill, CT
    I generally do three leaf cleanups each year but this year the wet weather kept getting in the way. so this week was crunch time. I needed to get the I6 Trojan to the farm, pick up a vintage cider press donation, and get the leaf pickup done. The zero turn has an issue we have not figured out, but it ran enough for a 5+ hour marathon today to get the leaves done. had to do a few "honey do" things as well.
    I need everything organized as i'm going to have hand surgery for carpal tunnel tomorrow morning on the right wrist. doc asked how long I've had it.....I said 40 years... started with problems riding a motorcycle and snowmobile and got worse with age.
    so I've lined up the pellet bags so I can just open them and load the stove, finished the leaves, and done everything I can think of to smooth the way....
    now it's time for a :beerbbq:or two:beerbbq::beerbbq:
    ivanhoe, CleanFire, jtakeman and 3 others like this.
  20. bogieb
    Argh! The P43 waited until a couple of minutes ago for the distribution motor to have issues; making funny whirring sounds and smelling like burnt stuff. Couldn't have done that last week when it was semi warm compared to what it is supposed to be this coming week. Now I'll have to go down and clean the boiler and get the pilot light lit - which means shutting down the P61a for a while (just in case of a gas leak).
