  1. wildwest
    got the left side and inside covers for impellar and heat exchanger :) . Did not do right side, I worried the computer panel would have wires I might pull out?
  2. wildwest
    I'm afraid its fried, just a nub left. The darn bold is cut on the other side too! No head on it.
    It's so soft I can't turn it with vice grips :headbang: This is the outside, the inside is about 1/4" no head.
  3. badbob
    badbob
    Might just be a stud and you can back it out,or run it in further and get with pliers from inside.Do not think there is a cleaning port on right side of stove,just convection blower to vacuum.
    wildwest likes this.
  4. wildwest
  5. wildwest
    Got the space heaters out, sun is settting and I did not finish......poor hubby has to come home and work more..... Good news is we are ready for another ton :)
    New nut, then close doors and start :)
    IHATEPROPANE likes this.
  6. wildwest
    Who suggested the paintbrush? Genious, thank you :handshake:
  7. wildwest
    Oh no, is this going on the Ahhhhh women........ thread?
    schoondog likes this.
  8. wildwest
    wrong term bob, sorry, guess its called a "wingbolt" ?
  9. badbob
    badbob
    Yes.Needs to come out.Goes into a nut that is welded on the backside.Spray with penetrating oil,tap on it and wiggle back and forth,probably will not be that tight.
  10. wildwest
    Good news!!! Found something in the garage and it worked!!! Sprayed it, tapped it the best I could, and it backed out, wooo hoooo!. Sorry camera batteries deadnow.
    schoondog and badbob like this.
  11. badbob
    badbob
    You got a sister?:D:D:D
    smoke show, wildwest and will711 like this.
  12. wildwest
    I finally identified the can, duct tape on it. Looks like gun stuff, Safariland cleaner lubricant preservative by Break Free.
  13. wildwest
    phew, hubby said it should flash off. Wiped off excess putting it back together.
  14. will711
    will711
    Pocono Mts.
    Great thread,
    Smoothies are good , and NO coffee in the afternoon don't work unless it's got some booze in it ;)
    Way to go Bob on helping her through this :thumbs: Have a Beer on me Bud :drunk:
  15. wildwest
    badbob
    YOU
    ROCK!
    Thanks!!
    will711 likes this.
  16. wildwest
    Turned the stove on. :popcorn:
    badbob likes this.
  17. wildwest
    no flashback from the gun cleaner :), she's up and running!
  18. badbob
    badbob
    Well sounds like you did everything but clean the flue,but if goes straight up not a big deal right now.Good job.
  19. wildwest
    Exactly, I cannot do that, and its been done pretty recently :). You must be a mind reader! And YES, it is straight up through the roof w clean out cap on bottom :banana:
  20. Gasifier
    Just finished a quick cleany of the stove. Always good to see the re-light when it's going down to -15 overnight!
    DexterDay and wildwest like this.
