  1. will711
    will711
    Pocono Mts.
    How about a bottle brush
    wildwest likes this.
  2. eatonpcat
    Am I suppose the clean down those tubes??
    wildwest and will711 like this.
  3. will711
    will711
    Pocono Mts.
    Jen I really don't know anything about your stove , sorry ,but like Eaton asked ,does ash get inside the tubes ??and what does the manual say about what needs to be cleaned ?
    eatonpcat and wildwest like this.
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Aren't you supposed to use the sweeping brush that came with the stove to clean those tubes? Then you remove the clean out ports and get the crud left in the bottom of the heat exchanger passages.
    ETA: For the rest of the gang she has opened up the combustion side of her stoves heat exchanger not the air output side. But in general both sides of the exchanger must be cleaned.
  5. eatonpcat
    Don't know...my manual doesn't mention cleaning them...I thought only air came through??
  6. will711
    will711
    Pocono Mts.
    Thanks Smokey :)
  7. wildwest
    :rofl: :lol: I thought he was joking!!!
    Yes, very specific instructions to use that specific brush INSIDE the tubes. With a warning it must me done in one motion. The tubes are atleast 1.5' long, I could not even get the brush more than a few inches down it.
    See page 37, am I using the tool upside down or something?
    http://www.drolet.ca/upload/documents/manuels/45725A_23-06-2014.pdf
  8. wildwest
    thank you for translating my womanspeak:)
    schoondog likes this.
  9. will711
    will711
    Pocono Mts.
    :rofl: :lol: Every once in awhile we are serious here ,don't let anybody know as we have our jokester reputations to maintain:D
    eatonpcat, smoke show and wildwest like this.
  10. wildwest
    I understood the directions to mean sweep the ash down the tubes from the top, vacuum the crud out of the bottom.
  11. badbob
    badbob
    The brush end goes into tubes.With a new brush is probably going to be tight untill gets some use.If too tight for you you could buy a softer brush like a bottle brush.If you need to finish today,straighten a clothes hangar,put a few kinks in it and work up and down in each tube while turning,will also tell you if there are any opstructions.
  12. will711
    will711
    Pocono Mts.
    Good advice there Bob :thumbs:
  13. wildwest
    THANKS!! Found an older wire hanger, need my fancified shower handle (vice grips) to bend it, in process!
  14. badbob
    badbob
    And,in case nobody ever told you,burn stove on high for 30-60 minutes before shutting down to clean.Makes life easier.
  15. badbob
    badbob
    If it was me,this late into day,would put coat hangar into cordless drill.
    RockyMtnHigh and wildwest like this.
  16. badbob
    badbob
  17. wildwest
    phew! the hanger worked great! No obstructions but it loosened alot than I vacuumed out! Going for a brown smoothie, 2 o'clock coffee not doin it for me. Now, I just need to replace the bolt on cover under the burn pot. I got the small piece of what was left of the wing nut off with my shower handle, now need to figure out how to get the bolt out. Drolet sent a new bolt and wing nut.
    will711 likes this.
  18. wildwest
  19. badbob
    badbob
    You also have 2 side panels to remove and vacuum on the left side.
  20. badbob
    badbob
    Also,if the new wing nut screws onto bolt ok,don't replace bolt,just use new wingnut for now.Bolt I believe screws in from back.
