  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    What did the doc hit you with?
    bogieb, CleanFire, jtakeman and 2 others like this.
  2. IHATEPROPANE
    IHATEPROPANE
    :heidi::emptywallet:
    imacman, bogieb, CleanFire and 4 others like this.
  3. gbreda
    gbreda
    NH
    lisinopril hctz: 10/12.5
    My RN honey says dont be surprised if they up the dose to if it dont drop enough. Says that is pretty standard procedure. I have always been in the mid 140's over eighty something. Spiked a few times to 90-91 and since I am seeing the doc every 2-3 months for an injury they are getting waayyyyy too many readings from me to stay under the radar. 3 months ago it was really good, dont know what happened 2 days ago.
    Honey says they want it under 80 which I generally am at 82 on a good day. Doesnt help that the standard for "normal" was lowered recently.
    savemoney, bogieb, will711 and 5 others like this.
  4. gbreda
    gbreda
    NH
    Yup. felt that way this morning about 2 hours after taking the med. A bit dizzy I guess.
    Luckily the med is only 5 bucks for a month supply. And so it begins..........
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    That lisinopril starts acting 1 hour after you swallow it and hits its peak hours later and the other is a loop diuretic (water or whizzing pill). Yes they start low and increase it. Do not use lisinopril if you are pregnant. If you become pregnant, stop taking this medicine and tell your doctor right away.
    savemoney, bogieb, artc and 5 others like this.
  6. jtakeman
    I take losartan 50 mg. I have no side effects, Thank goodness
    Mine too was caught because they where checking for other issues(thought I had lime) When I got nervous it would spike............ :loco: :crazy:
    bogieb, ivanhoe, CleanFire and 4 others like this.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    That 10/12.5 is a low dose, the boss has been on 20/25 for two decades. I have no loop diuretic and am on 40 mg lisinopril. The lisinopril doesn't make me dizzy, the CCB lowers my diastolic reading and sometimes both readings to hypotension readings.
  8. gbreda
    gbreda
    NH
    :doh:
    savemoney, bogieb, ivanhoe and 3 others like this.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Well just wanted you to understand it isn't baby friendly.
  10. jtakeman
    Losartan also has that warning as well.
    ivanhoe, IHATEPROPANE and CleanFire like this.
  11. gbreda
    gbreda
    NH
    Dont know why he did the diuretic. I have definitely felt "off" today. Even off for me that is. Felt fine before I took it. Hopefully I will assimilate :confused:
    Have an appointment in 3 weeks for a nurse visit and blood work. I just dis complete blood work in August-everything was good. I guess this is for potassium check?
    CleanFire, bogieb, ivanhoe and 2 others like this.
  12. gbreda
    gbreda
    NH
    Well, I made sure of no babies years ago
    Snip Snip
    imacman, CleanFire, bogieb and 4 others like this.
  13. jtakeman
    Better eat some banana's. These meds effect the potassium levels so I'm told.
  14. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    CCB = calcium channel blocker ( the 4th level of drugs sometimes needed for bp control). I refused to let them increase the metoprelol higher than 200 mg a day. Didn't want to involve a cardiologist in the mix.
    CleanFire, ivanhoe and IHATEPROPANE like this.
  15. jtakeman
    :axe:
    CleanFire, artc, ivanhoe and 3 others like this.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Yes it is for a potassium check as well as liver. Likely kidneys as well.
  17. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Usually if you are just above the normal range they sometimes will try just the diuretic to control things but it also allows a lower dose of the other drug to be used sometimes.
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I just came down stairs to top off the stove and should get back up the stairs before my second dose of met kicks in.
  19. gbreda
    gbreda
    NH
    I picked up some up when they said blood work for potassium but my honey said that these meds can increase potassium
    savemoney, imacman, CleanFire and 3 others like this.
  20. gbreda
    gbreda
    NH
    Thought that was going somewhere else....whew !!
    savemoney, imacman, CleanFire and 4 others like this.
