  1. jtakeman
    My air die grinder I got from them 20 plus years ago still works and will keep up to the Ingersol rand my shop bought.
    ivanhoe, bogieb, CleanFire and 2 others like this.
  2. imacman
    imacman
    Denver, NC
    Good stuff, from what I've heard, but never used it. PB Blaster is easy to find & pretty cheap.....always worked for me. I hope the Kroil works for you.....pulling a head (or both) is not cheap.
    ivanhoe, bogieb, CleanFire and 3 others like this.
  3. jtakeman
    The silverdohicky will get more aluminum and likely go all too. I hear they might even ditch dem push rods..............
    Lead or follow and seems GM is doing the later lately.
    ivanhoe and CleanFire like this.
  4. jtakeman
    Not cheap if you have it done, Much cheaper if you spin the spanners yourself. :D
    I might still pull off those chores. Just takes far longer these days. Hard to bend the old bones....
    ivanhoe, CleanFire, gbreda and 2 others like this.
  5. imacman
    imacman
    Denver, NC
    That's called smart. Let the blue oval spend all their time & $$ to work out the problems. The public doesn't care who did it first.
    ivanhoe, artc, CleanFire and 4 others like this.
  6. ChandlerR
    ChandlerR
    Seacoast NH
    Beat ya to it! Already in the basement :thumbs: My worry...'cause I worry too much....is when I put a pipe wrench on the gauge to unscrew it so I can pump the oil out, one of the rusty legs will collapse. So, I am building cribbing to support the tank just in case. The tank itself looks ok. The legs are baaaaaad.:bug:
    ivanhoe, IHATEPROPANE, bogieb and 2 others like this.
  7. jtakeman
    I think we stole most of em from others............ :whistle:
  8. smoke show
    smoke show
    Pittsfield, Wi
    Long azz chains suck. Seems even Ford has problems with them stretching and setting correlation codes...
  9. subsailor
    subsailor
    Winthrop, Maine
    The MWP softies aren't on the same level as other softies, like Lacrete or Spruce Pointe. They aren't worth the extra $$$ to me. The blend is a decent pellet at a decent price, at least up here. I plan on picking up a ton or 2 next month.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I'll wait till the sale is over it is only $89.99 then.
  11. gbreda
    gbreda
    NH
    Synthetic over the past few years
  12. subsailor
    subsailor
    Winthrop, Maine
    It looks like the warm temps are over for us up here. Dropping onto the 30's tonight and 20's and teens later in the week. High temp Sat. only in the 30's. I'll start chewing up some pellets now.
  13. jtakeman
    :picard:
  14. gbreda
    gbreda
    NH
    Change the clocks and you mess with the time-space continuum resulting in loss of heat retention.
    Or maybe it is really November and getting cold
    Either way it sux :tears:
  15. Ambient
    Ambient
    Northern New York
    :faint: Did did I miss someone's contribution stating that? Sorry, too many irons in the fire. We have a big distraction going on here in the house. :(
    Thanks
    ivanhoe, IHATEPROPANE, bogieb and 3 others like this.
  16. gbreda
    gbreda
    NH
    Is there something up with the weather stickies in sigs? Mine has had had the same thing for 2 days now and I see some with a X instead of the sticky
    Edit-Just checked this thread and its Wunderground issue
    Data unavailable
  17. imacman
    imacman
    Denver, NC
    33* here @ 6am. High for the day is only supposed to be 46* :shiver:
  18. imacman
    imacman
    Denver, NC
    I'm looking at yours right now, and it says 43*. They seem to be all working here.
  19. gbreda
    gbreda
    NH
    Right-it has said that for the last 2 days as well as tomorrow which I WISH was going to be 54 deg
    I wonder if yours is correct as it shows 42 degrees and last update of 8:53PM
    see this Data unavailable
  20. imacman
    imacman
    Denver, NC
    You're right....that temp's wrong, and I hadn't noticed the last update. WeatherUnderground goes through this occasionally. I don't see any data unavailable, though.
