  1. smoke show
    smoke show
    Pittsfield, Wi
    Look at the green grass!
  2. IHATEPROPANE
    IHATEPROPANE
    If it stays like this I will be putting the snow blower away for the lawn mower.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    You are not kidding, it's beautiful today!
    will711, wildwest and IHATEPROPANE like this.
  4. slvrblkk
    slvrblkk
    Northampton, PA
    I'll drink to that! :cheers:
  5. wildwest
    How are you two today? Better I hope?
    slvrblkk and IHATEPROPANE like this.
  6. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    Nice! Out of curiosity what leaf blower do you use? I need to get one of these set up here shortly. I like that you use a piece of flex to get it away from the house, genius!
    IHATEPROPANE and wildwest like this.
  7. wildwest
    Where does the other end of the flex pipe hook to?
  8. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    The end of the chimney system where the termination cap is located. This way it can suck all the ash out of the chimney and from what I've read it can also clean out the stove as well. Keep in mind it's still a good idea to pull the combustion fan once a year and clean off the fan blades as they will probably still have gunk on them. I use a small wire brush for this.
  9. slvrblkk
    slvrblkk
    Northampton, PA
    Leaf blower does a very good job of sucking ash out of the stove too. DO NOT FORGET TO DISCONNECT THE VACUUM HOSE FROM THE SWITCH IN YOUR STOVE BEFORHAND. Better to be safe than sorry than to screw up any vacuum switches.
  10. IHATEPROPANE
    IHATEPROPANE
    It's just a standard Toro with the Vacuum/leaf shredder option. Can be had for about $60.
    wildwest and slvrblkk like this.
  11. IHATEPROPANE
    IHATEPROPANE
    Yup, I undo mine. And to get the SOB back on I use a tiny bit of dishwashing liquid on the tube connection.
  12. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
  13. IHATEPROPANE
    IHATEPROPANE
    For those that may be unaware, you will need to replace the gasket on the combustion fan when you take the combustion motor off.
    wildwest, RockyMtnHigh and slvrblkk like this.
  14. slvrblkk
    slvrblkk
    Northampton, PA
    wildwest likes this.
  15. slvrblkk
    slvrblkk
    Northampton, PA
    The funny thing is I never undid mine but then during my first fire of the season I had a bad switch....hmmmm......
  16. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I guess they aren't designed to have 230mph worth of vacuum lol
    IHATEPROPANE, wildwest and slvrblkk like this.
  17. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I didn't have to :thumbs: but mine was only a year old. In most cases yes it needs to be replaced. I wish I could find a sheet of the material these gaskets are made of http://www.stove-parts-unlimited.com/Quadrafire-1000-Exhaust-Blower-Gasket-Large-p/812-0291.htm
    They would hold up to years of being removed and re-installed. I don't even know what to call the material besides "high temp silicone infused ceramic fiber wonderfulness". Everything these days is that cheap felt like ceramic fiber stuff that tears in half if you just look at it funny. I tried to google that term but nothing came up :D
  18. smoke show
    smoke show
    Pittsfield, Wi
    Didn't Donnie come up with something reuseable? Like the AE uses on the comb blower...
  19. slvrblkk
    slvrblkk
    Northampton, PA
  20. smoke show
    smoke show
    Pittsfield, Wi
