  1. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  2. bogieb
    81* right now - high temp was 87*. So much for their "in the 70's" prediction.
    ivanhoe, gbreda, slvrblkk and 2 others like this.
  3. CleanFire
    CleanFire
    Nah, they just hide the chit a little better now..
    Oil Filter:
    Radiator Cap:
    The Coolant Reservoir has a pressurized cap / replaces a separate Radiator Cap.
    Spark Plugs:
    Just a few special tools, like a good Torx set - the '08 Taurus has lots of those fasteners, on it here.
    ivanhoe, will711, gbreda and 4 others like this.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    really? thats crazy:headbang: wheres your thermo? read comin from?
    ivanhoe, CleanFire, slvrblkk and 2 others like this.
  5. bogieb
    Behind the house - in the shade - from a digital weather station. And I just looked on Wunderground, and a station not too far from me is reading a little higher - but it is out in a field and probably in the sun
    ivanhoe, PelletHound, gbreda and 5 others like this.
  6. IHATEPROPANE
    IHATEPROPANE
    Hope everyone is having a great Easter!
    Just ate and am loving me some Blue Moon honey wheat.
    Now to whoop my nephew in some wiffle ball.
    ivanhoe, PelletHound, ttdberg and 7 others like this.
  7. imacman
    imacman
    Denver, NC
    Well, I started thinking about it, and figured I'd try cleaning the air bleed with a thin piece of wire off a wire brush. Worked like a charm, along with some Carb cleaner spray. Re-assembled it, started right up, and no more surge. :dancer:I did see a tiny piece of crud in the hole, so that was the culprit.
    Slightly raised the idle speed too. Took the plug out, checked that & the gap, re-installed. Checked the oil, put a capful of Stabil in the gas, shook the machine around to mix it, started it and let it idle for about 15 min. Shut off, backed her into the shed, done until winter!!
    ivanhoe, PelletHound, bogieb and 6 others like this.
  8. imacman
    imacman
    Denver, NC
    Interesting that they're using cartridge-type filters again. Haven't seen one of those on a car since the early 70's.:confused:
    ivanhoe, PelletHound, gbreda and 3 others like this.
  9. CleanFire
    CleanFire
    It seems to be the trend again w/ the smaller boosted GDI motors, was reading an interesting article on it the other month (I'll see if I can find it again) - basically said the engine designers have more flexibility w/ tuning internal oil flow -> ducting -> placement w/ cartridge canister location, vs. a 'traditional' spin-on filter.
    Kinda makes sense: takes less square footage to unscrew a cap, and pull a cartridge out. And, if you can arrange placement so the clean oil flow is close(r) to the turbo, that doesn't sound too bad either.
    ivanhoe, bogieb, gbreda and 4 others like this.
  10. imacman
    imacman
    Denver, NC
    Seems that the environmental movement has something to do with this. Less material gets tossed in the landfill. See this article:
    Canister vs. Cartridge - National Oil & Lube News
    "California Department of Resources Recycling and Recovery reported if all of the spin-on filters sold annually in California were recycled, there’d be enough steel to build three large sports stadiums."
    In addition, easier to inspect the filter media for "debris". There is also the issue of more moving parts, and the possibility of not getting the o-rings seated right......hard to F-up with a spin-on.
  11. CleanFire
    CleanFire
    Thanks, good article. :handshake: All that makes sense, including the ability to incinerate an EOL cartridge, vs. sticking it in a landfill. I'm cool w/ that. :yes:
    I must have read the ' Engineer's article ' version.. :picard:
    Agree 100% is much harder to F-up w/ a spin on filter.. The canisters can be 'tricksy'. (I would be doing dealer change, or myself, if here. Which I do anyway. )
    imacman, ivanhoe, bogieb and 2 others like this.
  12. artc
    artc
    Rocky Hill, CT
    i recall as a kid checking carefully after changing the cartridge filter. on the 64 international pickup, one spit out 3 quarts of oil before you could shut the motor down! pinched gasket. i still check under the vehicle every oil change - spin on or not!
    and double check the tightness of the oil plug as well
    imacman, ivanhoe, CleanFire and 4 others like this.
  13. artc
    artc
    Rocky Hill, CT
    pulled down a Ford Model A engine today, before and after Easter dinner at friends. the engine is new to us and is slated for the Tieman tractor (a home made tractor design from 1950's Popular Mechanics)
    great news inside. a recent overhaul and new clutch were discovered. i think all i need to do is free up the valves and re-gasket it. we'll see if i have to grind seats or valves, or do inserts. need a special tool to remove the valve stems with the valves.
    imacman, ivanhoe, CleanFire and 2 others like this.
  14. gbreda
    gbreda
    NH
    I put a sheet of thick paper from the bottom of a ton of pellets under the truck in the garage to see if anything is leaking.
    I also leave one in the bed of the truck (soft tonneau cover used) and pull it out to the tailgate when I use the tailgate for a workbench-great for cleaning the chainsaw and other dirty jobs
    I save all of those paper sheets for odd jobs
  15. gbreda
    gbreda
    NH
    Rain coming in now for the cool down over the next week. Went to my sisters in Mass today-almost 90 deg there
    imacman, ivanhoe, bogieb and 3 others like this.
  16. ttdberg
    ttdberg Pellet Pig
    CT
    Changed the engine and cabin air filters in the Camry today. We had some friends living in there. Also there is a picture of the new filters that went in. Picked these up on A*azon. While I'm sure they will be fine, they do not "fit like a glove" like the Fram aftermarket engine / cabin filters for my Accord. Will be using Fram air filters from now on.
    savemoney, will711, imacman and 5 others like this.
  17. subsailor
    subsailor
    Winthrop, Maine
    It only took a few minutes yesterday of looking under the hood of my truck before I just shook me head and lowered the hood.
    savemoney, will711, imacman and 6 others like this.
  18. Earl764
    Earl764
    CT
    The AC is on.
    I worked for 5 hours outside on Saturday. Perfect weather in shorts to be working outside for long periods of time.
    Sunday, not so much.
    I need to do the oil on my truck. No so much the mileage, but the time. Lots of city driving, and it sits.
    will711, imacman, ivanhoe and 5 others like this.
  19. bogieb
    Still at 61* when I left for work this morning - great weather for the ride im!
    savemoney, schoondog, imacman and 5 others like this.
  20. eatonpcat
    Probably could have gotten a couple more months out of those filters!!
