  1. gbreda
    gbreda
    NH
    So the bolt started to come out and stopped? Is the head rounded or is the bolt spinning and doing nothing? If bolt spinning, it sounds like the bolt has stripped threads in the middle and that is a real PITA, but prying up my cut you a break.
    I have a Lady Foot Prybar in my arsenal that has been used alot over the years for when prying up was needed...
    Amazon.com: Mayhew Tools 60150 3-Piece Lady Foot Pry Bar Set: Home Improvement
    slvrblkk, bogieb, ivanhoe and 4 others like this.
  2. gbreda
    gbreda
    NH
    This thing has some miles on it
    bogieb, ivanhoe, will711 and 6 others like this.
  3. gbreda
    gbreda
    NH
    The more I think about it-if the issue is the bolt and is turning easy and you have a vise grip that can bite on the head you might be able to pull up while turning and catch some good threads. This is iffy because you will need a vise grip small enough to get in a likely small area and be able to turn in that area.
    Can you tell I have done had issues on older vehicles before? Being creative is a huge part of working on vehicles, especially older ones :headbang:
    slvrblkk, bogieb, ivanhoe and 2 others like this.
  4. gbreda
    gbreda
    NH
    Temp has risen to 10 degrees and sun is hitting the driveway...Time to make the donuts.
  5. jtakeman
    Don't think we got 3" here. Light fluffy stuff. In no hurry today, But will head out to clear it and go gas up sometime later today.
    I saw that I91 got shut down due to a 20 car pile up......... Aint seen that in some time. I guess the eastern part of CT got whacked a bit. Wondering how ttdberg made out??
    slvrblkk, bogieb, ivanhoe and 5 others like this.
  6. artc
    artc
    Rocky Hill, CT
    that was near my exit. it had all the secondary roads snarled for the day.
  7. CleanFire
    CleanFire
    Got one, that's Plan A to stop the spring clip from turning underneath. :yes:
    This is Plan B. Pulling the 20 gal. air compressor off the front porch -> to the wood shed and setting up for Impact wrench. :yes:
    A rescue vehicle cutting Saw is Plan C, starting with the front end.. :headbang:
    :D
    Got a shower, warmed up, full of caffeine, better cold weather gear on, time for round-2. :yes:
    Thanks for taking the time to post up the tips G ! Much Appreciated. :handshake:
    slvrblkk, bogieb, ivanhoe and 7 others like this.
  8. ttdberg
    ttdberg Pellet Pig
    CT
    Not exactly sure how much we got yet but it looks like about 6". Will report back later after we clean it up!
  9. ttdberg
    ttdberg Pellet Pig
    CT
    Was wondering if that was near you. The pictures on WFSB looked pretty nasty, hope everyone made it out of there ok!
    slvrblkk, bogieb, ivanhoe and 6 others like this.
  10. artc
    artc
    Rocky Hill, CT
    I like plan "C" cars are much easier to work on without all that silly bodywork in place. ditch the hood and front clip, and fixing it will be a breeze!
    that's why I like to work on farm tractors... the engine sits waist high and proud!
  11. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Good luck.
  12. slvrblkk
    slvrblkk
    Northampton, PA
    :D
    IHATEPROPANE, bogieb, ivanhoe and 6 others like this.
  13. PelletHound
    PelletHound
    SE Ma.
    Got 14" of sn*w overnight and went to start the snowblower and no go!!!:hair::headbang:.Got out the heat gun and warmed up the carb and she started.Put it in gear and the damm thing doesn't move.:headbang::headbang:.Take it apart in 2 deg weather and find the drive belt had come off the pulley.:hair:It ran fine 2 days ago when I prepped it for the storm.:doh:Got the belt back on and everything back together and it's working like a champ.:yes: IMG_6410.JPG IMG_6411.JPG IMG_6412.JPG
    IHATEPROPANE, bogieb, ivanhoe and 8 others like this.
  14. slvrblkk
    slvrblkk
    Northampton, PA
    It's always something!!!
  15. imacman
    imacman
    Denver, NC
    Maybe this would help? Methinks I may have to add one to the huge tool arsenal....tools are like pellets, never have enough good ones.
    15 in. Long Reach Locking Pliers
  16. imacman
    imacman
    Denver, NC
    Woke up to about 11* this morning, and had a dusting of sn*w on the ground. Temp is up to about 20*, sun is coming out......cars, road, & driveway almost all melted off already. Just used a broom to clear the deck & sidewalk. :banana:
    IHATEPROPANE, bogieb, ivanhoe and 5 others like this.
  17. CleanFire
    CleanFire
    Shouldn't you be skiing? :D
    Tractors are cool! Props & Respect for the work you do there artc. :yes:
    Gino's Plan A worked! pulled out the 3/4" ratchet, used a reducing adapter to fit the 8mm tiny socket on, the extra torque, & pry foot, did the trick. :thumbs:
    Torque value on this hold-down bolt is 44 inch/lbs. aka "tighten until snug", there was at least 10 ft/lbs on it, guessing. :picard:
    * Know who the culprit was - former mechanic that installed the battery, his motto was 'just torque it to 20 ft/lbs' .. And he always wondered "why" he kept breaking spark plugs, when trying to change out for maintenance. (He didn't last too long at the company.)
    Threads were good but rusty, cleaned up w/a wire brush, gave them a healthy coat of anti-seize, ran the bolt back down until the plastic foot was snug on the battery, it ain't moving, I'm calling it good. :thumbs: ( I'll check it over the next few days to make sure it's staying put. )
    Go skiing! You can drink later. :D
    :cheers:
  18. savemoney
    I go to Hannaford once a week. I check their meats area, but I admit I don't check the turkey. Whatever roast is on sale is what I get. same for the chicken etc. Sales usually have 2-3 backs a pound off the usual price. We also have a local IGA that has really good sales on meats and very good produce. I don't want to come off as a snob, but I avoid Walmart as much as I can. I hate the parking there and the checkouts are ridiculous. The only plus there is they have a Dunkin Donut so I can get a coffee after shopping.
    IHATEPROPANE, bogieb, ivanhoe and 4 others like this.
  19. gbreda
    gbreda
    NH
    Those are awesome, never seen that before.
  20. gbreda
    gbreda
    NH
    I love it when Plan A works. Its frustrating when you are on plan F or later. Then again, if A or B dont work, generally its plan BFH ! :rofl: :lol:
    When I was a mechanic at a dealership years ago, I walked past someones bay and he was sitting in the driver seat just staring at the dash. When I asked what was up he said there was a short he couldnt find due toi the fuse blowing so quickly. So he jumped the fuse and was waiting to see where the smoke would come from. :faint:
