Pellet Count for 2022/2023 Season
Discussion in 'The Pellet Bag' started by bogieb, Nov 1, 2022.
  1. bogieb
    36 bags used for February with a total of 133 used. Lowest total amount to this point in the heating season since I started tracking winter of 2016/17.
  2. Tullytown
    Tullytown
    North of Phila Eagles.
    3 tons exactly since mid October.
    burn 24/7 most times when needed...
    bogieb likes this.
  3. Birddog91
    Birddog91
    Lakes Region NH/Connecticut
    Not really tracking, maybe 25ish bags?
    bogieb likes this.
  4. jtakeman
    53 bags of GS's
    5 bags Somersets
    50 lbs of corn
    30 lbs of cherry pits
    Approx. 10 gallons of #2 HHO
    Season total of 233 bags of pellets so far! :emptywallet:
    Not counting CP-Corn or HHO
    bogieb likes this.
  5. bogieb
    Just filled the P43 and realized it is end of month. Since the P61a was filled yesterday, no use waiting to count what I've used.
    32 bags were used in March, for a total of 165 for the season. The next closest year was last year at 30 more bags plus use of the mini-split whenever it was above 15 or 20* (and not windy). Last winter was also fairly mild, but February's average temperature was much colder than this one (18* versus 31.5*), so that right there makes the difference
    jtakeman likes this.
  6. Skier76
    Skier76
    CT and SoVT
    I’d say about 2.5 to 2.75 tons thus far out of the three purchased back in the fall.
    bogieb likes this.
  7. jtakeman
    57 bags for March.
    Season total 290 bags.
    Switched to HHO for April and May or however long it lasts. Approx. 110 gallons to burn before tank removal.
    bogieb likes this.
  8. Tullytown
    Tullytown
    Just under 300 bags. Speaking of oil tanks, had ours replaced few months ago. Looks like a storage locker..that domestic storage tank to the right is new also. Stone line insulated. No electric. Gets fed from oil furnace and water can stay 130 degrees 7 hrs or so. Saves lots of oil. Still hooked up to hot water baseboards but pellets burned 99% of winter.
    bogieb likes this.
  9. Iron Stove
    Iron Stove
    Central CT
    Right about 2 tons. Will be a bit more with cool nights this week.
    BTW, my grass is getting green ! Buds on trees, maybe first mow in 10 days or so ?
    Skier76, bogieb and jtakeman like this.
  10. bogieb
    That is an interesting looking oil tank - I like it. You'll love that hot water storage tank. At my old house we switched to using one. It not only saved lots of oil, it kept our basement from heating up during the summer since the boiler only had to run 1-2 times per day.
    Tullytown and jtakeman like this.
  11. Skier76
    Skier76
    CT and SoVT
    I totally bet! It’s crazy how fast things are greening up.
  12. Tullytown
    Tullytown
    Btw my mistake. Just under 200 bags or 4 tons.
    bogieb likes this.
  13. Iron Stove
    Iron Stove
    Central CT
    My brother had a bad stretch of luck. During a snowstorm, power outage and surge fried his Harman pellet stove computer. Then 2 weeks later after filling his oil tank, it started leaking. He too now has a Roth double wall tank. Was a very expensive month.
    Tullytown and bogieb like this.
  14. Tullytown
    Tullytown
    power outage fried our fridge few yrs ago.. Not when power went out, But when power came back on there was a surging sound that wasn't nice then it went out again.. power came back again later.
    filed claim with PECO and got 1,000.00 which is the Max..
    anyhoo, now when power goes out, we shut the fridge breaker off at the main panel and don't turn back on till power has been back on and stabilized for 30 minutes or so..
    can't put a surge protector for the fridge because if it trips for whatever reason and your away from home, vacation whatever, the fridge will stay off forever till it gets reset.
    bogieb likes this.
  15. bogieb
    15 bags for April, for a total of 180 so far. Cool and rainy all week so will be continuing usage - just at a low amount. I've burned to the end of June before so am by no means anticipating the end soon. Rather be heating a couple times a day than cooling for 8 hours anyway.
  16. jtakeman
    Still holding Season total 290 bags.
    Approx. 70 HHO for April
    bogieb likes this.
  17. bogieb
    Probably my last report for the 2022/23 season (if not, then mother nature has some 'spaining to do).
    I used 4 bags from the stacks in May. I shut down the P61a and emptied the hopper (about 1/2 bag) into the P43 on May 15. Before I went on vacation a couple of weeks ago I added another bag to the P43 (it did run a few times while I was gone). It is supposed to be a cool weekend plus a few days into next week. So it's possible the P43 may run, but I won't have to add to it.
    So, that gives me a total of 184 bags this burning season. It was a mild winter and this is the lowest total I've ever had. I totally ran just the pellet stoves for heat - never used the mini split. The previous low was 205 (lst year), but that was also running the mini split for heat during shoulder seasons and also thru a lot of January when it was mild.
    Edit: I was looking at / completing my spreadsheet and suddenly noticed a number off by itself that changed when I put in the May numbers. I realized it is my total usage since I started the spreadsheet. Unfortunately, I don't have my first 2 full winters of usage, which were my heaviest use at 5-6 tons each year. That was before I installed basement insulation and raised flooring (and other odds & ends thru the years throughout the house). But since the 2016/2017 season, I've used 1730 bags (34.6 tons)
    jtakeman, Skier76 and Tullytown like this.
  18. jtakeman
    Approx. 45 HHO for May.
    I hope were done, But still a lil oil left in the tank to get ride of.
    bogieb and buZZsaw BRAD like this.
  19. jtakeman
    Luck ran out and snapped the heat on for a wee bit. Got a bit chilly even for me in the shack with not much sun happening!!
    bogieb likes this.
  20. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    Used 152 bags of wood pellets. Slightly less than the average of past winters of about 175 bags.
    Used about 25 gals of HHO heating oil over two cold spells. Which is 1/2 of the average
    of 50 gals. of HHO in past winters.
