Pellet Count for 2021-2022 Season
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by bogieb, Dec 3, 2021.
  1. ivanhoe
    ivanhoe
    Northern Ontario
    90 for January, not a typo :faint:Never seen this before:startled:
  2. bogieb
    :eek:
  3. jtakeman
    x2 :eek: :faint:
    CleanFire, gbreda, ivanhoe and 2 others like this.
  4. ChandlerR
    ChandlerR
    Seacoast NH
    I'm at 87 so far. About the same as last year. I used 125 bags last season.
    CleanFire, gbreda, bogieb and 2 others like this.
  5. gbreda
    gbreda
    NH
    54 bags so far. Have 21 left in basement and hoping to not have to break into the unopened ton in the garage.
    Should be able to shut down for the next 4 days with temps above normal.
  6. bogieb
    I used 33 bags for February, for a total of 156 so far this year. I figure approximately 22 of those went thru the P61a (about 3/4 bag/day). So only about 11 bags for the P43. But, I've been using the mini split whenever the temp is over 20* so using less for the main floor than previous years.
    CleanFire, jtakeman and imacman like this.
  7. gbreda
    gbreda
    NH
    9 bags left in the basement so 66 this season. Those 9 will go quickly if the temps dont come up a bit.
    May have to pick up 10 or so in order to burn thru end of March. At this point I dont want to open the ton of Matra in the garage-not wasting those on shoulder season.
    50+ degrees forecast for Monday so hopefully this is the last real cold. Or not :p
  8. jtakeman
    3 bags total plus =
    470 gallons of Juice guzzled and 300 more added to the tank. Approx. $2500 clams give or take. Last fill was $3.54/gallon(or $1056.00). :doh:
    Hoping it gets us through until mid May.
  9. gbreda
    gbreda
    NH
    My last fill was at 3.699/gal :eek:
    Hoping that gets me well into or thru the summer by using the stove. Probably not though.
    Just picked up 15 33lb bags of LG Super Premium to try out. The Super Premium supposed to be the same as LG but smaller bags.
  10. Pete Zahria
    Pete Zahria
    New Hampster
    If I recall.. they have less dust /fines..
    They used to go through one more step of blowing them before bagging.
    Not 100% sure, now.. but they did..
    Dan
    bogieb, gbreda, imacman and 1 other person like this.
  11. gbreda
    gbreda
    NH
    Henry did mention that.
    imacman and bogieb like this.
  12. gbreda
    gbreda
    NH
    Same place is $3.99 as of this afternoon for home heating oil. Gas is now $3.56
    WTF
    bogieb likes this.
  13. imacman
    imacman
    Denver, NC
    UNLIKE!!!! :mad:
    bogieb and jtakeman like this.
  14. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    We have used about 2.5 tons of shells so far.....
    The last couple days have been much warmer than the past several weeks....Big stove shut off and the little Whitfield is handling the show....
    This really cuts back on the fuel usage.
    The little stove will use two 5 gallon buckets a day (Soap pails) vs nearly 4 for the big stove
    That's 24 hrs
    Our stoves run 24/7 during the cold season.....Late spring will see a more spotty use.....Spot fires in the morning to take off the chill....
    This year we have used a bit more shells than in some years past...
    Depending on the weather....we may do a 5th haul..... The plant manager said they should be running into March....maybe a bit later.....
    PelletHound, bogieb and jtakeman like this.
  15. ivanhoe
    ivanhoe
    Northern Ontario
    Another high usage month, 64 :faint:
    So fed of this winter, words can't describe on how I feel about it :mad:
    Late Easter's are always the blame for longer than usual winters :doh:
  16. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    The weather is giving us a break FINALLY
    Been able to keep the shack warm during the day using only the little Whitfield.
    Past couple mornings we have needed a boost from the Big Boy as the inside temps dropped to 65/67 F overnight....33 F outside this morning.
    Instead of 4 buckets of shells to go 24 hrs we are at 2 now......Much better ...
    Cleaned the little stove yesterday and polished up the drop tube mouth (I carbons up and will tend to drop the shells more to one side instead of on the spreader bar the scatters the materials on the fire evenly "subjective" )
    Definitely a colder winter than we have have seen in a few years.
    bogieb likes this.
  17. scajjr2
    scajjr2
    Kingston, NH
    Used about 3 tons since Nov. Have 8 bags of Vermont, 3 tons Wood & Sons and 1.5 tons of the Doug Firs left.
    sam
    bogieb, imacman and jtakeman like this.
  18. ChandlerR
    ChandlerR
    Seacoast NH
    8 bags to go and I will be at 2 tons. Same every year.
    PelletHound, imacman and bogieb like this.
  19. imacman
    imacman
    Denver, NC
    I still find it amazing...all the years burning pellets, all different kinds of winters, and the pellet count was always pretty close to the same.
    bogieb, PelletHound and ChandlerR like this.
  20. ChandlerR
    ChandlerR
    Seacoast NH
    I think, in my case, my house is so small and so very well insulated, the stove never has to work very hard. Not to mention I am on the coast so my weather is usually moderated by the ocean.
    bogieb and PelletHound like this.
