OWB Can’t keep up after pump change
Discussion in 'OWB's and Gasification Boilers' started by cigarsmokingzombie, Nov 13, 2019.
  1. JCMC
    JCMC
    Just outside of Shushan, NY
    I use one of those inferred temperature guns point it at the inlet of the HE then check the outlet.
  2. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    I’ll take a pic, I don’t even know what the HE looks like.
  3. Heat550
    Heat550
    Minnesota
    That's great info .. we got that figured out but there's more issues he needs to fix . He had the pump sucking the water thru the 2 exchangers he has .and now he will re plumb it and get pump pushing water thru the plate exchanger and air exchanger . I don't know how it even worked like that . It was only the equivalent of a 007 taco pulling 75 feet and thru 2 exchangers . I think boiler water weight was only thing feeding the exchangers. Ya he will be a busy guy.
    O oooo and burned that pump up also .
    Sent from my LGL84VL using Tapatalk
    brenndatomu and yooperdave like this.
