Overcome, improvise, adapt
Discussion in 'The Wood Pile' started by Timberdog, Jun 15, 2020.
  1. Timberdog
    Timberdog
    Az
    So I wanted to use my firewood permit and go cut in the forest this afternoon but the forest is under a Stage 2 fire restriction which prohibits me from using “a chainsaw or other equipment powered by an internal combustion engine between the hours of 9:00 AM and 8:00 PM.” so......
    I now have a small inexpensive Harbor Freight cheapie electric chain saw I got to trim off limbs before I buck the main trunk and for other small trim work so being the firewood addict I am, I had to get my fix. So I thought I would try my little 10” electric saw. I was quite impressed. I was expecting to make only 3 or4 cuts before it gave out. But I made 6 per battery and I have 2 so I was able to cut a dozen rounds and nearly fill my small compact pick up truck bed with Douglas Fir. Took a little longer than my Stihl and I had to make two cuts with the short bar but I managed to secure a good haul for my fix. A nice little back-up saw.
  2. Chaz
    Chaz
    Southwestern NY
    Wood's in the truck
    I'd say it worked out well.
    :yes:
    Gonna get a couple more batteries?
    Or just charge n go
  3. Chvymn99
    Yea, the battery saws have came a long ways in recent years... I really like mine... Nice job on the wood gettin' too...
  4. buZZsaw BRAD
    Hey were addicts, uh, i mean hoarders right? We find a way to get our fix.:woodsign:
    I bought a DeWalt pole saw in April and have used it a few times and am impressed with it. Had three batteries already so it helped as i bought the bare tool. Thought about getting the battery chain saw.
    When you bring a PU full of batteries then there may be a problem!:rofl: :lol:
    Great job Timberdog :thumbs:
  5. JPDavis
    JPDavis
    Prescott, AZ
    In my area we can go to the fire dept. and get a day permit to cut on residential property, we call in with our name and the address we are cutting at then at the end of the job we call in and tell the fire dept. we are done. We have to bring a fire extinguisher, shovel and have a garden hose nearby. We're also suppose to have a designated person to watch the process making sure that a fire isn't started. If you're cutting in the National Forest, I'm not sure if they use similar guidelines, But I've had to use battery powered saws this time of year before the monsoons arrive and it can be a pita. That little saw has some power to get through rounds that big in diameter.
  6. Eckie
    Eckie
    Is this just to cut at your housein your yard or what? Does the garden hose have to have a water supply..or do you just have to have a hose? Does your area get any/many fires started from chainsaws? Is that a hitting rocks and sparking thing, or hot saws/mufflers/ spark arrester thing? I am a bit baffled by that process/need...
  7. tamarack
    tamarack
    paulina oregon
    Ya Arizona must not have got much snowpack in the high elevations. Here in eastern Oregon I think we will make July 10th or so before they put on the 1 pm shutdown. Electric chainsaw? That's a great idea you had to get around the fire restrictions.
  8. Eckie
    Eckie
    What does that shutdown mean?
  9. Backwoods Savage
    Timberdog I'm sure you are happy you got that saw now. Maybe time to get an extra battery now too.
  10. Timberdog
    Timberdog
    Az
    Might get one more if they don’t lift the fire restrictions soon.
  11. Hookedup24
    Hookedup24
    Bucks county, PA
    Good job getting your fix! How heavy are the rounds? Could you cut them twice as long and halve them at home?
  12. Timberdog
    Timberdog
    Az
    Naw, it’s easier on my back to cut them to 18” before I get home. They are pretty heavy —too heavy to lift two at once and injure myself.
  13. tamarack
    tamarack
    paulina oregon
    It's a restriction on chainsaws, mechanized logging equipment, welding, and cutting torches. These are prohibited from 1 pm to 5am during the level 3 caution level. Also no campfires or briquet BBQ's. This is on USFS land. Probably varies a bit from State to state.
  14. T.Jeff Veal
    Great way to adapt and overcome.
    Good load of wood too.
  15. Ron T
    Ron T
    Northeast Ohio....Bowdil
    What are the penalties for non compliance.
  16. Screwloose
    Screwloose
    I was just cutting yesterday and I was watching chips landing on my muffler and sparking away. I can surely see it starting a fire.
  17. Timberdog
    Timberdog
    Az
    Nothing I like. Fines, confiscation of equipment, liabilities to damages...And I don’t want to be the idiot who breaks the rules and then starts a forest fire.
  18. tamarack
    tamarack
    paulina oregon
    The majority of the wildland fires are started by lightning. Unattended campfires probably in second place. The rules certainly make sense when the Forest lands get very dry in late summer.
  19. Screwloose
    Screwloose
    Your face on TV.......for some firewood.
  20. amateur cutter
    Yea, nothing like burning a few thousand acres for a truck load of wood.
