Our Wood Yard Adventures
Discussion in 'The Wood Pile' started by Krackle_959, Sep 21, 2024.
  1. Krackle_959
    Krackle_959
    Coastal Maine
    Got to spend the day in the woods today putting the new chains to the test. It’s an amazing amount of traction, no tire spinning hauling 4-16’ logs so far. We had gotten a few snow storms since I was last out in the woods, roughly 12” of snow on the trails now. Went out and packed the trails down and skidded logs on the way back.
    Ended the day with a decent pile of maple, birch, beech, black cherry, ash, and a red oak limb that had broken off. All storm damaged trees from last years storms, it’s slowly making a dent in them. Not the biggest wood, but it’s free. Will spend the morning bucking them to 8’ and adding to the pile.
    Cavtrooper, WinonaRail, RCBS and 11 others like this.
  2. eatonpcat
    Those chains are nice!
  3. Krackle_959
    Krackle_959
    Coastal Maine
    Spent some time today out in the woods before the wind got to be too much. 30mph + gusts takes all the fun out of felling trees. Cleaned up 2 maple and a birch that were rub trees on the trail from when we had it logged. I had the loggers leave all the hardwood rub trees for firewood, it’s worth more to me as wood than the cash. Shortest log is 16’, the birch was 3-16’ logs before a single branch, and then it split to 3 tops. Both maple gave me 2-16’ logs and then some smaller tops.
    Cavtrooper, RCBS, brenndatomu and 8 others like this.
  4. Krackle_959
    Krackle_959
    Coastal Maine
    As I was skidding logs, and a grapple of top and limb wood it made me think of a question. For people who fell trees for firewood how small of diameter limb/top wood do you take?
    For me it’s about the size of a soda can, anything smaller goes to the chipper or left for deer to munch the tops this time of year. Here’s a photo of a maple top wood that came out in the grapple today. IMG_5527.jpeg
    Cavtrooper, RCBS, brenndatomu and 7 others like this.
  5. buZZsaw BRAD
    Years back when felled trees were our only source we'd harvest down to 2" limb wood. Today I'd go 3" but seldom harvest full trees anymore. If I'm at a score or the dump and its an "exotic" wood il take down to 3" or so. Now with a steady source for larger diameter logs I doubt I'll touch it anymore.
  6. Krackle_959
    Krackle_959
    Coastal Maine
    Thanks! My FIL was trying to get me to cut limbs down to 1” diameter for wood as he sees leaving it as wasteful. He cuts his wood that way on his property, and I think dealing with such small limbs would be time consuming for the end results.
  7. Krackle_959
    Krackle_959
    Coastal Maine
    Went up to the wood yard after lunch to cut the logs into 8’ lengths and add to the firewood pile. The pile is getting big, 8’ wide, 7’ high avg, and 20’ long, I didn’t include the last couple feet at half height.
    I’ve got some “poverty sticks” as I call them in the backyard to skid up to the wood yard, cut to 8’ length and add to the stack, and that’s probably it for hardwoods this year. The backyard trees are 40’-60’ tall and at most 8” at the butt, they grew up around existing apple trees, and competed with pines for light. I’ve been slowly cutting them back to expose the apple trees to more sunlight. There will end up being a huge chipper pile from these trees. I’ve marked a couple sugar maples and a beech to save for yard trees, hopefully they grow into nice trees. If not, more firewood.
    metalcuttr, Cavtrooper, RCBS and 6 others like this.
  8. Krackle_959
    Krackle_959
    Coastal Maine
    Spent sometime this afternoon in the woods getting some hemlock logs out before we loose all of the snow and frost. Unless it gets cold again I’m probably done until summer. Went to where I was winching logs yesterday, grabbed the butt log left from yesterday, and a 16’ log from tree #2. Then grabbed tree #3 from that spot which ended up being 43’ long, not quite as nice as the others.
    my 550xp is out there at the edge of the tree trunks, 160’ away.
    hard to tell the log on the right is 43’ long as it ended up in a skidder rut.
    metalcuttr, RCBS, brenndatomu and 5 others like this.
  9. Krackle_959
    Krackle_959
    Coastal Maine
    Finished the afternoon with a third tree that gave a 18’ log and a 24’ log. Didn’t take action shots for some reason.
    Here is the tractor all geared up for logging, I need to find a better place to put the gas and bar oil. It’s currently between my feet.
    The end result of two afternoons in the woods, a decent stack of hemlock logs. One butt log has heart rot, so it’s going to get hollowed out and make a couple planters for the wife. I’ll bring the mini ex up tomorrow morning and buck everything to 8’ and stack it on dunnage.
    metalcuttr, RCBS, Stephiedoll and 7 others like this.
  10. Krackle_959
    Krackle_959
    Coastal Maine
    Spent yesterday bucking up firewood logs from the pile. Made a good sized dent by dinner time, and called it a day. It was getting foggy and not nearly as nice as the morning.
    Lunchtime break.
    On another note my 550XP stopped oiling all of a sudden. Looks like I’ll be tearing into it tomorrow while it’s raining. Also going a little slower today, I’m a little out of shape apparently.
  11. Dok440
    Dok440
    NorCal
    That's a big operation! After the snow melts do you have to wait for the area to dry or can you keep using it?
  12. Krackle_959
    Krackle_959
    Coastal Maine
    Just a one guy show. The frost in the ground is quickly leaving as temps have been pushing 50 for a couple days. The snow is also mostly gone, still some frost under the log pile. I can’t drive a tractor on it until it dries up some, but the mini excavator can be used. I smooth out the wood yard each night when I’m done incase it freezes overnight temps have been in the 20’s. Makes working the next day easier.
  13. Krackle_959
    Krackle_959
    Coastal Maine
    Today’s progress, not as much done as I wanted. Neighbor came over for a visit which was a nice break. Running the 372XP with a 24” bar all day bucking firewood is a good workout.
    pics are from the cab of the excavator so the pile looks shorter.
    Yard all smoothed out before it rains tomorrow. It’s fun trying to grade sloppy mud. IMG_5586.jpeg
    metalcuttr, Cavtrooper, RCBS and 7 others like this.
  14. Krackle_959
    Krackle_959
    Coastal Maine
    Haven’t updated this much lately, the weather has been rain or snow every couple of days for the last 3 weeks. Got ready to take the snow blower off the small tractor and the wife informed me we were going to get 5” of snow. Ended up with 4” of heavy wet snow, and it made a mess of things.
    Progress has been made though, finished up bucking the hardwood pile, and shorts pile.
    Moved onto the poplar log pile and got that done as well.
    metalcuttr, Cavtrooper, RCBS and 4 others like this.
  15. Krackle_959
    Krackle_959
    Coastal Maine
    Had some free time this morning, so I took the 592xp up to the wood yard, and cut up the hemlock pile. Took a few hours, and it’s done. I didn’t really need to use the 592xp, but that’s not why I have it. It does make me smile every time I run it!
    Tomorrows plan is to take the snow blower off, get the loader on the tractor, then grab the wood splitter, and do an oil change. It’s suppose to rain tomorrow, so if I get it all done, I might tackle changing teeth on the stump grinder as well.
  16. Krackle_959
    Krackle_959
    Coastal Maine
    Got out to the wood yard today for 3 hours of splitting. We got 1” of snow on Tuesday night, so yesterday was a wet mess as it melted. Made a decent dent in the stack, got a long ways to go.
    Getting setup.
    Progress pics.
  17. Krackle_959
    Krackle_959
    Coastal Maine
    Spent a good amount of the day in the wood yard today. It rained and snowed this weekend so no work then. Made some good progress on the pile, and put 5 hours on the splitter. Moved a couple totes to start filling them when I need a break from splitting. It’s gonna be crappy weather tomorrow, and I’m pretty sure my wife has volunteered me for yard work at the in-laws place later this week.
    The pile is shrinking a good amount!
  18. Canadian border VT
    Great pics Krackle_959 looks like great area..
    I have been doing same on MUCH smaller scale
  19. Krackle_959
    Krackle_959
    Coastal Maine
    Thanks! We have been working on our backyard/field since fall of 2021. It was all woods then, and a long process to turn 10 acres from stumps to field. Even started an orchard last year on 2 acres hence the deer fence in the back of some of the photos.
    My wife says nothing I do is small, I tend to agree. I’m really working on a 3-4 yr plan for firewood, and should achieve it this year.
  20. Krackle_959
    Krackle_959
    Coastal Maine
    Got the hemlock and the poplar split for kindling and shoulder season wood. Brought the splitter down to the house, cleaned it up, and tucked it away for a while. Finished the day by filling 2 totes with mixed hardwood. The ground is starting to dry up, so I’m going to bring the 4052R out to the wood yard and move some full totes to the storage area and see if I bury it in the process.
