Our house in the woods build
Discussion in 'Everything Else (off topic)' started by DaveGunter, May 22, 2018.
  1. NortheastAl
    NortheastAl
    Putnam County NY
    DaveGunter The look on that poor guy’s face is enough to get me. Hope it isn’t hurtin' too much
  2. Backwoods Savage
    Enjoy the milling Dave. It can be fun although it has been many moons since I've done any I still have the memories.
    Can't help but feel sorry for the pup. I've seen some really nasty ones but even a couple can hurt them a lot. So how did you go about getting the quills out?
  3. DaveGunter
    DaveGunter
    I was able to get them to my vet that afternoon, you have to knock them out to make sure you get them all and to not get bit when pulling them out, especially when they are in the snout like they always are, I've been quilled, it hurts way worse coming out.
    I trapped another one overnight last night. The dogs picked up on it before I could even see the trap on our walk this morning, a few hundred feet from the trap. One of the two that got quilled the other day turned around and went home, the other made a big arc around the trap, so maybe they learned?...they've been quilled before though, so I don't know...I'm hopeful. The other three dogs stayed with me and I let the porky out with them right there, it walked right by Oliver on its way to climb a tree, he did not react to it, the others just kept their distance.
  4. Flamestead
    Flamestead
    Windsor County, VT
    Looks like you’ve figured out how to load your logs already, but check out parbuckling some time. This was used before hydraulics and tractors. With the low trailer, you could probably load them with your JD that way.
    Nice screened porch!
  5. basod
    basod
    Mount Cheaha AL
    One thing I don’t miss about Maine porcupines and skunks- none in my area here.
    What’d you use for the screen porch- is it a magnetic clip type?
  6. DaveGunter
    DaveGunter
    The screens are on a track at the top and snaps on the sides and bottom. There is a magnetic door at one of the posts too.
    No skunks seen yet, I'm sure they're around, at least neither are lethal. I'd probably have to have a stash of anti venom in your area, the little Jack/Beagle is obsessed with snakes.
  7. NH mountain man
    NH mountain man
    WMNF N.H.
    Great pics of the wood and home site Dave, dogs in pain, not so great. We have a lot of Quillpigs here as well. We even see them eating the grass in the spring. Hopefully the dogs will be fine from here on in.
  8. basod
    basod
    Mount Cheaha AL
    Anti venom is rarely administered to dogs. Unlike humans they don’t get all worked up and will just go lay around and mope for a couple days. Minnie our 18lb piglet chiwinnie is the only one to have been tagged by a pit viper in her front armpit -not sure what kind her belly turned bruised color. Vet put her on antibiotics and she was back to normal in a few days.
  9. NortheastAl
    NortheastAl
    Putnam County NY
    This is good to know. Thanks, basod
  10. DaveGunter
    DaveGunter
    Did a little milling with my buddy today. I know nothing about saw mills but this looks like a nice mill and set up. The blade pivots 90 degrees.
    I brought a few cedar logs that weren't hollow and all kinds of twisted, wishing for some 4x4 posts and some 2x4 for the ground contact part of the chicken coop I will be building.
    Here's today's take, the longer 2x4 are either pine or spruce, the shorter stuff is cedar. Some thick cedar slabs for planks over the wet spots on my trails. We worked for about 4 hours but took our time and he explained a lot. He kept some lumber for himself too.
  11. DaveGunter
    DaveGunter
  12. basod
    basod
    Mount Cheaha AL
    That’s sweet known as swing blade mills.
  13. Well Seasoned
    That's great DaveGunter! Looking forward to the build!
    We've had a porcupine last week and again last evening. Seems they can climb trees way faster than they can walk.
    Hopefully they move on. Maple has been chasing Jack rabbits, there's a ton of them everywhere this year!
  14. bogieb
    It was fun seeing the hack rabits at the G2G! Hopefully Maple stays away from Porky though.
  15. DaveGunter
    DaveGunter
    :hair:, got another Porky yesterday, just a baby, I think it was an orphan, that makes 9 since we've been here, Oakley showed it to me, he kept going back to the same area and barking, I finally saw it when he actually pulled it out from under a rock!...not sure how but he did not have any quills in his mouth.
    Chickens might be awhile, the spot I want to put the coop and run still needs some ground work. I can't seem to get the contractor back here to do the work, it's been so wet this spring he's behind and I'm sure he got bigger $ projects in the works.
  16. Well Seasoned
  17. Well Seasoned
    I hope so too!
  18. DaveGunter
    DaveGunter
    It's big excavator and some dozer work for sure. The drive need to be dressed with a few inches of fines, some pretty big stumps pulled and boulders moved and probably another 150 yards or so of fill brought in and spread around. We are going to let that settle out for the summer and then some loam this fall to get some stuff growing in the ground around the house to hold everything in place.
  19. DaveGunter
    DaveGunter
    Finally, 10 months later, got the site work contractor back yesterday to finish up some final grading around the house and top dress the drive with some fines. We had no issues with water in the basement, but I'd like to get the water moving around the house so we can keep the dirt where it is and start some planting...been two years without a proper garden. Started yesterday, should finish up today. I'm taking the day off to supervise cuz I'm gonna get it the way I want it;).
    Threw a shoulder on to keep me busy.
    Chaz, Stinny, NortheastAl and 16 others like this.
  20. Gasifier
    :thumbs:Very nice Dave! Home looks awesome!:thumbs:
