Optimizing a Craftsman while saving for a "real" saw
Discussion in 'Chainsaws and Power Equipment' started by HighCountry, Jan 26, 2016.
  1. dougand3
    dougand3
    North Alabama
    Never seen a 42cc Poulan (Craftsman) or smaller with anything but 3/8LoPro. At 46cc+, you'll start seeing .325.
    HDRock and HighCountry like this.
  2. HighCountry
    HighCountry
    New Mexico
    That is the chain that I use now in the 18". I will stick with that chain on the shorter bar.
    Viking80 and Eric VW like this.
  3. Eric VW
    Good points, especially about sharpening teeth that come into contact more often due the reduced # of cutters.:thumbs:
    Real good info sharing, too!:saw:
    :thumbs:
    clemsonfor and HighCountry like this.
  4. HighCountry
    HighCountry
    New Mexico
    It is a 3/8" Lo-Pro. The bar is the stock one that came with the saw, but like dougand3 said, I use the Oregon 91VXL062G on that bar and will probably stick with that chain.
    clemsonfor and Eric VW like this.
  5. HDRock
    Yeah U right , I wasn't thinkin straight :)
    clemsonfor, HighCountry and Eric VW like this.
  6. Eric VW
    :zip::zip::zip:
    J/k HDRock :thumbs:
    clemsonfor, HDRock and HighCountry like this.
  7. HighCountry
    HighCountry
    New Mexico
    So, I guess the real question is does the benefit of having less teeth (and any gained speed) outweigh having to sharpen the fewer teeth more often? This is really where I am having an issue.
    Kyle Mulligan, clemsonfor and Eric VW like this.
  8. HDRock
    Just keep the chain sharp , keep the chain sharp, every couple of tanks
    Not this :eek::)
    Shawn Curry, Eric VW and HighCountry like this.
  9. HighCountry
    HighCountry
    New Mexico
    Hey, that looks familiar! That chain is currently hanging in my garage, in the same state, to serve as a visual reminder of how far my education has come. All thanks due to this great group of people, by the way. :yes:
  10. Eric VW
    As long as you're not bull ridin' that saw into the wood, inspect chain every few tanks like HD suggests....a couple of passes with a file in a decent guide should be handy.
  11. HighCountry
    HighCountry
    New Mexico
    My "new" chain certainly does not look like this one, and I have been doing my best at keeping it maintained well. I am, by no means, a pro at sharpening yet, but I am getting better every time.
    Shawn Curry, HDRock and Eric VW like this.
  12. HDRock
  13. HDRock
    445 is .325 :)
  14. Eric VW
    Yep, it sure is. Wish I could make mine Picco.... . Any thoughts?
    That ms170 zings through wood with that narrow kerf!
    clemsonfor, Barcroftb and HighCountry like this.
  15. HDRock
    445 comes with Narrow Kerf Pixel .325
  16. clemsonfor
    yep that came to mind...I got one:)
    HDRock likes this.
  17. clemsonfor
    If you just so much as nick the dirt that chain is dull ad all get out! Keeping your chain out of the dirt or reducing the amount of dirty wood you cut makes a chain last a long time between sharpenings.
    Watch when bucking wood on grohnd. If possible try to get something under it to hold it pu and if uou must buck to the ground I go very slowly that last bit and just poke the tip into the log barely cutting till I get to the bark.
    CTYank, Shawn Curry, HDRock and 2 others like this.
  18. HighCountry
    HighCountry
    New Mexico
    That is definitely the bane of my woodcutting existence around here. All of the wood here is extremely dirty. We are so windy here, and most of the trees have little nooks and crannies that catch all of the dust and dirt flying around. I am extremely careful about not hitting the ground, but it seems like the trees themselves have just as much dirt in them as the ground does! :picard:
  19. Eric VW
    Sounds like you've gotta bring a hose and water supply, or a some port-a-air just to clean off this mean ol' dirt! :headbang:
    I know it's not helping your budget, but could you look towards a carbide chain=stronger teeth?
  20. HighCountry
    HighCountry
    New Mexico
    If carbide chains are worth it, I will look into them. I did not know that they even existed. I have used carbide for power tool blades, with success. Research time! :sherlock:
    Eric VW likes this.
