???? On Clinkers
Discussion in 'The Pellet Bag' started by oldspartantrader, Feb 3, 2016.
  1. oldspartantrader
    oldspartantrader
    Northern NY
    In this mild weather I have been using the hammers and have noticed that compared to the softies I get a clinker as well as a bit of carbon on the burn pot.
    Before experimenting with upping the air to the chamber I thought I would ask if hardwoods generally require a more combustion air than softwoods in a pellet stove. I am thinking that the carbon and clinker is from not introducing enough combustion air.
    Stove is clean, vent is clean, gaskets are all good and when burning Lacrete or Platinum the clinker, carbon is not apparent. That leads me to believe the "issue" (and it is not a big one) is one of combustion, hence air.
    OR
    Am I missing something else??
  2. IHATEPROPANE
    IHATEPROPANE
    Generally for me, when burning Hardwoods, more air is required than with softies. Even less air with blends.
  3. will711
    will711
    Pocono Mts.
    I can't adjust the air on my Harman's , so I really don't know .
  4. oldspartantrader
    oldspartantrader
    Northern NY
    OK - Thin
    I bumped the air a bit for the night after doing a scrape down so I shall see what I shall see come tomorrow
  5. oldspartantrader
    oldspartantrader
    Northern NY
    Although 1 bag of pellets is hardly enough for a real test --
    A 6% increase from 85 to 90 volts at the combustion motor has visually ended the issue. Going to let it play out through Saturday.
  6. CleanFire
    CleanFire
    Sounds like you got it sorted out OST, cool. :yes:
    Dunno what the weather is like in your neck of the woods, but if you can save the Softies, that's a beautiful thing.. It's early/mid Spring weather here this week. :thumbs:
  7. oldspartantrader
    oldspartantrader
    Northern NY
    Was 50 here today -- Been like spring. Linda's tulips have popped through in one of the beds, or maybe they are daffodils. I just get to dig.
    This has been one of the warmest winters in my recollection (and that goes back more than I care to admit).
    The caking was bothering me - BUT - I believe it was an air issue because the stove has almost continually been on the lowest setting. Just had to think it through. Still learning pellets after decades of wood.
    will711, Rich250, Pete Zahria and 3 others like this.
