Older Daka add on Wood furnace installation
Discussion in 'Modern EPA Stoves and Fireplaces' started by akeller, Nov 14, 2020.
  1. brenndatomu
    Not for the supply ducts...and galvanized should never be used for stove pipe anyways, so...
    Why's that, you'd rather pay full price?! :eek: I thought Yoopers were "frugal" :whistle:
    I find Menards site to be less than user friendly sometimes too.
    And using (2) sections of 6" to make 12" is an excellent idea! :yes: :handshake:
    yooperdave likes this.
  2. akeller
    akeller
    Wouldn't you have to flip one of the pieces?
    Then that would mess up how the duct fits into collars?
    Sent from my SM-N981U using Tapatalk
  3. brenndatomu
    Yes...while the one is "unzipped", pound the crimps flat on the formerly male end, then add crimps to the other (formerly female) end with your new crimping pliers from Menards ($20 ish IIRC)
    https://www.menards.com/main/heatin...ct-pipe-crimper/thht-1444/p-1488180036833.htm
    6 x 3.14 x 2 = the same as 12 x 3.14 (37.68)
  4. yooperdave
    No, you don't to flip one piece. You will see. Seam A fits into seam B with crimp on top. Lay first pipe with crimp at top and seam A on your left. This leaves seam B looking for a mate. 2nd pipe with crimp at top, seam A on the left again. This seam A of the 2nd pipe will mate with the seam B of the first pipe. You'll see. Just watch out for those pipes when they couple this way. It can be kinda tricky.
    akeller and brenndatomu like this.
  5. yooperdave
    Not so much as paying full price, it's more that I'm tired of waiting 2 months for the rebate to show up! And, their sales are better than 11% anyway.
    :handshake:
    343amc and brenndatomu like this.
  6. brenndatomu
    Yup...you right...oops :emb:
    Good thing somebody around here knows what they're talking about! :D
  7. yooperdave
    Ha! Surely, you're not speaking of me?
    You know how many mistakes Eric VW has corrected on my posts????? Cripes, I think for awhile there, he had me on "speed correct"!!!
    Eric VW and brenndatomu like this.
  8. Eric VW
    yooperdave and brenndatomu like this.
  9. akeller
    akeller
    some times the brain moves faster then the fingers..
    Happens to me quite often
    Isnt that quite amazing how the brain works. Because when I read that my brain put the word there that was missing and I didn't even notice untill brenndatomu pointed that out.
    brenndatomu likes this.
  10. yooperdave
    So.........
    Are you in the U.P?
    Or from "under the bridge"?
  11. akeller
    akeller
    I'm from under the bridge.
    About an hour or so NE of Grand Rapids
    brenndatomu and yooperdave like this.
  12. akeller
    akeller
    Well guys,
    I got the plenum installed.
    I ended up going 10" ducting
    Now to just hook up the cold air return to the blower[​IMG][​IMG]
  13. brenndatomu
    That looks better.
    Now then, is that galvanized pipe hooking to the chimney? If so, bad idea...galvanized pipe can give off some nasty toxic fumes when you get it over 750*, which is not hard to do with those old school burners.
    akeller and yooperdave like this.
  14. yooperdave
    Phosgene gas from burning off the zinc plating, I think?
  15. akeller
    akeller
    No not galvanized in chimney.
    Its all 6" black chimney pipe.
    I also made a chimney cap with a rain cap.
    I have a 8" black pipe around my 6" for the rain cap.
    The screen is no longer on the rain cap I took that off and will re install it in late spring to keep birds out
    [​IMG][​IMG][​IMG]
  16. akeller
    akeller
    For me to hook up my cold air return to my blower. Do you think I would be okay to use 7" duct?
    I have enough of that already in my basement and don't have to spend any more $ on it
  17. brenndatomu
    No...the return air needs to be ~20% bigger than the supply...so if you went with 10", that's 12" for the return...sound right yooperdave ?
  18. yooperdave
    We (businesses I worked for) always upsized the RA a bit.
    Look at it this way, the 10" leaving the wood stove plenum carries right around 350 cfm (a bit less)
    7" pipe feeding the air to the wood furnace carries about 150 cfm (a bit less).
    The numbers show that system is starving for RA. This can create more problems by increasing the velocity of the RA to make up for the "shortage".
    Without having to go into needless detail and the what ifs, just increase the size of the pipe to the RA.
    Another way to get around this is to install a RA grille into the plenum (box) of the return air on the wood furnace. Drawback of this approach is that the air would not be drawn from the living space as well as it should be.
  19. yooperdave
    Did you install an elbow in the gas furnace plenum with the elbow pointing up and away? And a manual damper in the supply (10") from the wood furnace? Hope so.
    Also, its important to filter the air before it enters the wood furnace.
  20. brenndatomu
    Having run both ways, (with and without RA hooked up) the supply temps tend to run about 10* warmer with the RA hooked up.
    Might not be as big of a deal with an old school furnace, but the newer HE stuff tends to run with lower supply temps, (over a longer time though) so an extra 10* can mean a lot...
    moresnow and yooperdave like this.
