Old stove....
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Eckie, Dec 16, 2019.
  1. Eckie
    Eckie
    I just combed over the stove...no name, no tag, no plates, no place that looks like a name came off...anywhere. you may be able to tell from the pics, but it does have a jacket on both sides...also has a similar jaclet on the bottom of the stove. And there is a blower on the back.
    Chaz and wildwest like this.
  2. Eric VW
    Looking at that flue transition, I’d almost think this appliance started out as an insert?
    To be fair, I’m not familiar with those old buck look a-likes.
  3. Eric VW
    Where yat in VA?
  4. Eckie
    Eckie
    Dont know what it might have been before. The pipe necks down because we had a chimney sweep line the chimney, it was cracked when we bought it. So i guess they had to use 6 inch, hence the neck-down in size going in the wall.
    In nottoway county.
    Chaz, wildwest and Eric VW like this.
  5. BHoller
    BHoller
    Central pa
    Most bucks can be either inserts or freestanders they still do it.
  6. BHoller
    BHoller
    Central pa
    That may cause performance problems
    Chaz likes this.
  7. Eckie
    Eckie
    Yeah...i had wondered about that, but i guess they had to.. Don't know if i could get another flange piece or whatever its called, the piece that comes off the stove, that is 6 inch on top and make it all 6. But i reckon it was made to use 8 inch.
    Anyone have any ideas of new stoves that would work with my "setup"
    Chaz likes this.
  8. BHoller
    BHoller
    Central pa
    Most modern stoves would work fine there
    Chaz likes this.
  9. Rich L
    Rich L
    Eastern Mass.
    Ya the manual does show a glass door image.So your knock off idea seems valid.
    Chaz likes this.
  10. BHoller
    BHoller
    Central pa
    It could also be an early unlisted buck I don't know. But if it is unlisted you can't assume it is the same as a listed one. You have to go to the default clearances
    Chaz and Rich L like this.
  11. Stumpy75
    Stumpy75
    Toledo, OH
    I agree that if it's unlisted or an unknown, you should go with the default clearances. BTY, the original Buck stoves did not come with glass doors. They were solid, as the picture shows. My brother bought the glass doors after he installed the stove.
    And I don't mind the blower. It's worked good for 25 years or so...
    Chaz and BHoller like this.
  12. BHoller
    BHoller
    Central pa
    When installed as a freestanding stove the blower is fine. As an insert it is horrible.
    Chaz and Stumpy75 like this.
  13. RabbleRouser
    RabbleRouser
    In the woods, New Hampshire
    Guess I know several people that need to be arrested and flogged for their dissidence. Which code nazi office of the supreme authority should I report them to?
  14. BHoller
    BHoller
    Central pa
    Just don't expect your insurance company to pay a claim if there is a problem. I have a stove in one of my garages I did it knowing the risks involved. I am ok with insurance not covering that structure or its contents. But there is no way I would do it in my business shop or the garage where I park my personal vehicles. It just isn't worth the risk.
    For the most part no one will make you follow code. But if anything ever happens there are consequences for ignoring them
    Chaz and brenndatomu like this.
  15. Stumpy75
    Stumpy75
    Toledo, OH
    Even though it's an old version of the manual that I gave a link to earlier, they still refer to nfpa 211 as a reference...
    I could see a lot of problems with that too, but a friend has been using one for about 25 years, as an insert. He pulls it every fall and cleans things up(including the chimney), and oils the motor. I realize that he's just one person, and he does the needed maintenance(which many won't do).
    wildwest and Chaz like this.
  16. BHoller
    BHoller
    Central pa
    Pulling one when it is actually hooked up right is a real pita.
  17. Eckie
    Eckie
    I'm going to try to get this stove up and running...not sure when i can get a new one and need a heat backup plan soon.
    There is no fire brick in this stove. Should i go get some of the thin bricks and try to at least line the bottom? Should i try setting some up on the sides? Or sand in the bottom?
    I am going to measure where the stack meets the stove to know which gasket i need and try to order. Wish it was something i could do/use that would last sufficiently that would be easier than ordering that and putting it in (if the cement i bought will crack due to heat fluctuations)....
    Chaz and Eric VW like this.
  18. Eric VW
    Definitely don’t bother with the furnace cement that comes in a caulk tube.
    I prefer Rural King’s Furnace cement in the tub. Follow the directions and you’ll get a lasting seal.
    I would half brick the bottom and a run of splits around the sides, vertical standing.
    Add a hearth pad out front and some sheet metal to extend the brick backing (stood off the wall 1”), and let ‘er rip ‘tater chip.
  19. BHoller
    BHoller
    Central pa
    Buck stoves and most of the copy's didn't use firebrick so there would be nothing to hold them in place on the sides. And Durance cement will not hold up if used to fill gaps. Can you post a pic of the problem area?
  20. Eric VW
    That can be addressed.
