Old Skidoo 2 Stroke Oil
Discussion in 'Chainsaws and Power Equipment' started by MeanJoe, Aug 15, 2026 at 5:18 AM.
  1. MeanJoe
    MeanJoe
    Western Michigan
    Does anyone remember running Skidoo 2 stroke oil in chainsaws? Came in metal cans with a tab on top like a pop can. I have a couple old sealed cans I want to use up. Thought I’d run it through my old 70’s Echos. I mix at 32:1 for them.
    Thoughts?
  2. Eric Wanderweg
    I seem to remember a couple lengthy discussions about the dangers of running 2 cycle oil designed for water cooled engines in air cooled engines. I would steer clear.
  3. MeanJoe
    MeanJoe
    Western Michigan
    Interesting! Never thought about that. I’ll look into it. That era some snowmobiles were liquid cooled and some were air cooled.
    eatonpcat and MikeInMa like this.
  4. Mrxlh
    Mrxlh
    Dat Boot
    Boat oil isn’t the issue in an air cooled engine. It’s the actual oil itself, Treemonkey runs boat oil in saws, zero issues for him. Being that Bombardier spec’d the oil for their power sports equipment it should be fine. Liquid cooled sleds go back a bit, I think as early as 73 for the high end models. Knowing the add packs back in the day weren’t nearly as good as we have now, I’d definitely mix it rich.
    eatonpcat, Ronaldo and MeanJoe like this.
  5. MeanJoe
    MeanJoe
    Western Michigan
    For the old Echo’s I mix at whatever the manual said. Most are 32:1 but the 500 is 20:1! The mosquitoes fly away when that’s running.
    eatonpcat and theburtman like this.
  6. Mrxlh
    Mrxlh
    Dat Boot
    If you’re using old oil, definitely, if you’re using modern oils, 32:1-40:1 is plenty. I run everything I own at 32:1 with Amsoil Dominator. If I ever start milling wood, I’d run that at 25 or 20:1 as long milling cuts generate tons of heat.
    eatonpcat, MeanJoe and theburtman like this.
  7. The Wood Wolverine
    I always mill at 40. Tore the saw down multiple times and it's doing just fine. Some cuts required more than a tank of fuel!
  8. MeanJoe
    MeanJoe
    Western Michigan
    Great to know! I’ll burn up the gallon of 20:1 I have and then just mix at 32:1 for the old saws and 50:1 for the new ones. I was very surprised when that manual said 20:1, must have been one of the last models that took that much oil!
    eatonpcat likes this.
  9. MeanJoe
    MeanJoe
    Western Michigan
    Wow! How much oil do you use per tank of fuel when milling?
    eatonpcat and The Wood Wolverine like this.
  10. Skier76
    Skier76
    CT and SoVT
    As odd as it sounds, those may be worth more to a collector vs running them in a saw.
    RCBS, eatonpcat, Ron T and 1 other person like this.
  11. The Wood Wolverine
    I mill with my regular mix, 40/1 but with a fat tune.
  12. Canadian border VT
    Well I still have a liquid cooled and air cooled ski doo from 90s and it was same 2 stroke skidoo oil in both sleds and they would still run with some carb tinkering
    I did not mix a ratio then oil in separate containers in engine
    brenndatomu likes this.
  13. brenndatomu
    Yamaha used the same oil (Yamalube 2S) in both the air and water cooled sleds (among many other machines)...2M is for marine engines.
    I have been running all of my 2 stroke stuff on YL 2S mixed at 32:1 or 40:1 for many years now...but that gallon jug is very near gone now...it'll be RA from here on out.
    Might have to slow the autolube pump on the sled down a bit, depending on how it does at current settings running the RA...but that machine has not moved for WAAAY too long now, so...
