OK.. It's freakin hot in here..
Discussion in 'Everything Else (off topic)' started by Chaz, Mar 6, 2018.
  1. Chaz
    Chaz
    Southwestern NY
    Wow, I never really thought I'd be opening up windows in winter.
    Had 2 face cord of wood delivered on Sunday, it's much larger than we normally split to, and well seasoned.
    I'm not certain on why, but I decided to fill the stove tonight, actually got 4 splits to fit in the stove.
    I'm quite certain that it's the first time that the external therm hit 500° since we installed the stove.
    Room temp is at 80° and was climbing until I opened up the upstairs, and a downstairs window.
    The primary air is sitting at the first large hash, so 1/4 open. Not much action aside from occasional bouts of the secondaries, but HOT!!
    This thing can put out some SERIOUS heat. I love it.:dex:
  2. TurboDiesel
    We had ours smoking a couple nights ago.
    I went down to give it one last look before bed . When I got to the top step I could feel way more heat than usual . I went down and found the stove room in the low 90's and the stove front was 777° ...
    I cut the air back for a few minutes and it settled down, but never did figure out why it was so hot.
    It had cooled down outside pretty quick that night and was very clear. I am guessing it was the weather causing a better draft than usual. .
  3. Shawn Curry
    Shawn Curry
    Western NY
    This is the second year in a row where I had stacked a bunch of locust on the porch but it never really got cold enough where we needed to use it. So we’re working on it now cause I don’t leave any stacked there during the summer. It’s made for some pretty toasty sleeping overnight! :fire:
  4. Chaz
    Chaz
    Southwestern NY
    It's not very cold here tonight, right around 30°.
    Our house is small, the upstairs is usually closed off by a door, and I've only filled the stove pretty well once before.
    It did not respond as robustly then as it has tonight, I'm certain that his wood being better seasoned than ours has a LOT to do with that.
    On the plus side, if I were to do my wood to the same size as his, it would save me many hours of splitting. Bad side, Jill is not liking the size of the splits.
    We all know that the second part of that carries MUCH more weight than the first part. :bug:
    Hell, if I can get these splits dialed in for a 12-14 hour burn, I'll feed the beast before work and before bed and be a happy camper. :thumbs::thumbs:
  5. Shawn Curry
    Shawn Curry
    Western NY
    Tell ya what, my stove just doesn’t run right unless the box is full. Even with dry wood I’ll end up with a smoky fire that’s hard to get going at first. I think that probably had a significant affect for you in this case.
    I like to use the “log cabin” method - with 3 layers cross-crossed. So I usually like to keep my splits around 3-4” or less. But as long as most of the volume in the box is consumed, it runs very consistently. We like hot and clean.
  6. Chaz
    Chaz
    Southwestern NY
    That in a nutshell is the ONLY reason that I can see for forced air furnaces (NG/LPT/FO).
    They turn on and off as needed. The don't generally "run hot" and cause problems, no chimney fire issues to worry about.
    As for cost, I seem to recall that it ran us between $1,000 and $1,300 per winter to run the furnace.
    It got to the point that when I heard it run, the only thing that went through my mind was money blowing out of the chimney.:emptywallet::emptywallet::emptywallet:
    I'll be sticking with wood for as long as I'm able to do so.
  7. Chaz
    Chaz
    Southwestern NY
    If you mean my previous concerns with the stove, I do believe you are correct.
    Aside from the one time, we've never really filled it and ran it full.
    It's a mental block that we both have to get past, and her a bit more than myself in this case.
    As you and others state, the stove is very controllable, but she' likes to 'see' the fire, and I'm averse to hot-azz temps.
    So, it generally is not used appropriately, barely above cat range most of the time.
    We will get past this, but as everyone knows, bad habits are often difficult to unlearn.
  8. Shawn Curry
    Shawn Curry
    Western NY
    You get used to it. I taught Amy to run the stove too, and now we can just heat “on demand” rather than on a set schedule.
    So it’s just like the furnace but the temp swings in the house are a bit more than you’re used to. But once it gets a little chilly, it feels real nice to crank that baby up. :fire:
  9. yooperdave
    You're doing it right.
  10. Backwoods Savage
    You guys don't know what a warm house feels like! Come on around here and we'll show you a warm house. :rofl: :lol: And if you don't believe me, just ask My IS heats my home as he enjoyed it during last year's GTG. :rofl: :lol:
  11. Chvymn99
    I think Shawn was in there too at that time... unless the bon fire wasn't done at that time :fire:... But My IS heats my home .... Just happened to be snuggling up a little closer to the fire than the rest...:D
  12. Backwoods Savage
    Ya, I believe you kept warm too.
  13. Eric VW
    Thankfully Chaz is who he is.
    Now, if a man chooses to wear a long, long shirt, and no pants (aka a dress), then such would be chilly more often.:shiver:
    This is not directed at you Chaz :yes:
  14. Chaz
    Chaz
    Southwestern NY
    I'm not sure I want to know where that one came from. :loco: :crazy:
    The long, long shirt thing had me thinking of the old school nightshirts, complete with nightcap.
    Straight outta Charles Dickens and such.
    Glad I didn't have to live through that.:bug:
    Although if I remember correctly my father did have some experience with the 'coal holders' that they used to use to keep beds warm back in the day. Wish he was here to confirm or deny that story.
    It's only 78° tonight, stove is running like a champ. :thumbs:
  15. Chaz
    Chaz
    Southwestern NY
    Didn't think so, no worries there.
    I do get the impression that it may be pointed @ Backwoods Savage but I could be wrong there also.
    No biggie to me either way, I own no 'nightshirts', and Jill "might" have a dress in the house, but I don't have the legs for dresses. :jaw:
  16. TurboDiesel
    That's not exactly how I remember the story...:whistle:
  17. Shawn Curry
    Shawn Curry
    Western NY
    Oh trust me, :D you really don’t. :rofl: :lol:
    Then again, ya couldn’t possibly have your thread derailed by a nicer fellow. :p
    You coming to the GTG? :coldone:
  18. Eric VW
    No... not Backwoods Savage....:yes:
  19. brenndatomu
    It wasn't just the stove heat...there was some auxiliary "heat" too... :fart: :faint: :picard: (and not me either!)
  20. Chaz
    Chaz
    Southwestern NY
    LOL:rofl: :lol::rofl: :lol:
    As if this thread was actually headed to some logical endpoint. ;)
    I like the sense of humor on this board, and this thread was never in danger of being Hijacked or thrown off the rails.:thumbs:
    As to the GTG, which GTG, and when.
    I cannot answer at the moment, have to make a determination later.
    Although I can honestly say that I do look forward to one of the gatherings, I think it'd be a blast.
    :saw::tree::axe::drunk::grizz:
    But there'll be no dresses involved, nor nightshirts. :rofl: :lol:
    (well.. not by me at least, others may do as they please.)
