Oil boiler is leaking water intermittently.
Discussion in 'The DIY Room' started by Warner, Mar 7, 2020.
  1. Warner
    Warner
    First supply store I showed the guy a pic of the valve he gave me a 35psi valve that did not work out well.
    brenndatomu likes this.
  2. TurboDiesel
    Either the system is getting too much water pressure when cold (could be 7-10#) or the bladder tank is bad if the pressure is going over 35 psi
    Mitch Newton and brenndatomu like this.
  3. Warner
    Warner
    Why would there be a 150 psi valve? That was the original valve in the hot water tank
  4. Warner
    Warner
    With the 35 psi valve water was shooting out of it
  5. brenndatomu
    Hmm...I'm "speaking out of school" here, but I think that first valve may have been the right one...
  6. brenndatomu
    Yes, makeup water valve/pressure regulator bad.
    TurboDiesel likes this.
  7. Warner
    Warner
    35 psi?
  8. brenndatomu
    Different rules/design specs for DHW tanks and "boilers"...
  9. brenndatomu
    Yeah.
    Although I have only ever seen 30 PSI used.
    Could you read the tag on the old valve?
    You definitely want to have the correct one on there...could get expensive (and even worse, dangerous) having a 150 on a 30 PSI system.
    See if you can find a data tag on the boiler somewhere that says what its rated to run at.
    And look at the makeup water valve/regulator, see what pressure it is...12 PSI is common...that means if the system pressure goes below 12 PSI the valve will open and allow water in.
  10. Warner
    Warner
    The original valve I replaced was 150 psi it was what was on there since day one
    TurboDiesel and brenndatomu like this.
  11. Warner
    Warner
    Make up valve says 12-15 psi
  12. brenndatomu
    Hmm...I guess I will have to defer to someone with more expertise than me on this one...but didn't you say the guy that put this system in was a hack?
    I'd still look for a data tag on the boiler...
  13. brenndatomu
    My "spidey senses" are telling me that 150PSI is wrong...maybe yooperdave would know something about all this...
  14. yooperdave
    Sorry, my boiler experience is next to nothing!
    But, I do know that typical operating domestic boiler pressures are only 12-15 psi.
  15. Warner
    Warner
    Yeah the guy was a hack but the system has been operational for 12 years with out issue.
  16. brenndatomu
    Just got lucky? PRV only does its job when something else goes wrong...
  17. brenndatomu
    Maybe he put a 150 on it because the makeup water pressure regulator was bad from the beginning?
  18. billb3
    The hot water at your washing machine or anywhere else for that matter is isolated from the boiler water by a coil in the water tank.
    The hot water is at street pressure 35-50 PSI (or more), your boiler should be much, much lower, closer to 10 0r 15 PSI.
  19. Warner
    Warner
    Hmmm...
  20. brenndatomu
    Do you still have the 35 PSI valve? (even that one is potentially a bit high) If so, you could put it back on and let it leak...then turn off the makeup water...if the leaking stops then the makeup regulator is bad.
