Official yard cart/ utility trailer thread
Discussion in 'Chainsaws and Power Equipment' started by TurboDiesel, Jun 8, 2015.
  1. Redfin
    Redfin
    central Pa
    I do enjoy saving money savemoney.:D. Mama even painted it with a mix of leftover latex from the house. I love this woman.
  2. savemoney
    That makes it even more special !
    clemsonfor and Horkn like this.
  3. Horkn
    It matches the Eiger.
    I'm thinking this one from Harbor freight would work well for me. 870 lb. Capacity 40 in. x 49 in. Utility Trailer
  4. HammerheadC4
    HammerheadC4
    Eastford CT
    Darkimpulse, HDRock and Horkn like this.
  5. TurboDiesel
    ^^^this^^^
    Horkn likes this.
  6. clemsonfor
    Haha. Look at that cab on the lawnmower!
    That cart has fenders even, wow!
  7. clemsonfor
    Looks like you in camp ground maintenance with that cart
    HDRock likes this.
  8. Horkn
    A piece of plywood for the floor, put some boards in the slots for the side boards, and it's all set.
    This heavy duty steel utility trailer features built-in slots to place your own side panels and built-in lighting for safety while driving. Just hitch it up to a vehicle with a 1-7/8 in. ball hitch and this utility trailer will roll securely on its 8 in. tires. Assembly is easy and a baked enamel finish helps keep the utility trailer in peak performance condition.
    • Heavy duty steel frame with baked enamel finish
    • Steel frame has built-in slots for stake siding (stake sides not included)
    • Leaf spring suspension
    • Two 8 in. diameter tires (spare tire sold separately)
    • Complies with applicable DOT standards
    • Easy assembly
    No international sales. Due to an age restriction, you must be at least 18 to purchase this item.
    Specifications
    Name 870 lb. Capacity 40 in. x 49 in. Utility Trailer
    SKU 62646
    Brand Haul-Master
    Assembly Required Yes
    Certification DOT compliant tires
    Finish Baked Enamel
    Foldable (y/n) No
    Material Steel
    Maximum GVR (lb.) 1000 lb.
    Trailer fitting 1-7/8 in.
    Product Height 19 in.
    Product Length 6-4/5 ft.
    Product Weight 130 lbs.
    Product Width 4-3/4 ft.
    Shipping Weight 122.80 lb.
    Size(s) 40 in. x 49 in.
    Tire size (in.) 8 in.
    Accessories Included coupler, safety chain, wiring harness, trailer light kit, and license plate holder
    HDRock likes this.
  9. clemsonfor
    Yea thats what I thought they looked like I didnt recognize his...this had me thinking there was a yard cart version too?
    Horkn likes this.
  10. fuelrod
    fuelrod
    Western Maine
    I have a big yard:whistle: but I know how y'all like pics. DSCN7871.JPG Actually you guy's might think I'm wasting this (Basswood), but it's going in the swamp to make a "corduroy" road. Not worth working up for firewood, about as useless as Lanthis or "tree of Heaven".
    tamarack, reprod, Stinny and 6 others like this.
  11. clemsonfor
    How long will that last? 2 years? Till is rotted to mush?
  12. TurboDiesel
    Update on the Brinly 17 yard cart
    I've decided after 1.5 years that the Brinly can't handle heavy tasks even though its says 850 pound capacity .
    The side AND the bottom of the tub has broke.
    I have the owners manual and it claims a 2 year warranty on the tub, but, even if they replace the tub, the warranty is going to run out in a few months and I'll be left with a flimsy plastic ticking time bomb....
    :doh:
    Lesson learned...:(
    Should have built my own or bought something more industrial strength!!!
    Barcroftb likes this.
  13. M2theB
    M2theB
    Central Massachusetts
    IMG_3824.JPG IMG_3823.JPG I've shared this pick before. This is two independant single axles. Allows the bed to stay pretty level. I've got lots of rocks to get over. Advertises as 20.5 cu.ft. And 1250 lbs capacity. It's on the high end for price, Northerntool has it at $429, which is much better than what I paid for it at HD in December.
    It replaced the 20 cu.ft. Craftsman that had the snot beat out of it. So far it's exactly what I was looking for. It has a dump, but for wood it's kinda useless.
    Yutrax X4 utility trailer
  14. clemsonfor
    Is there a pic of this? I just saw a kitty and a file not found pic back at the begenning
    TurboDiesel and Hammy like this.
  15. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    This looks like a good one. You are such a nice fella that I bet the guy would knock $50 off.
    yard trailer
  16. clemsonfor
    Is that yours?
    TurboDiesel likes this.
  17. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    No, I just did a quick search in Tim's part of PA. I'm a craigslist searchaholic!
  18. Gasifier
    I'm looking for something a little heavier duty with good ground clearance to pull behind my tractor. Maybe something like this which is up on craigslist close by. Don't have the cash now though.
    Utility Trailer
    These DR look nice. But expensive. Single axle 1000 lbs capacity and tandem axle 2000 lbs capacity.
    These tandem axle trailers from Northern Tool look nice for ATV size. Good capacity. Two models at 1500 lbs or 1200 lbs capacity.
    Keeping in mind that freshly cut firewood can be real heavy and the pounds can add up very quickly.
    Barcroftb, reprod, ChipsFlyin and 2 others like this.
  19. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    That CL one looks like an old re-purposed manure spreader. You can probably find one a lot cheaper than that (they always rot out), pull out all the slinging mechanism and re-board it yourself...?
  20. Gasifier
    If I come up with $400 I was thinking of offering him that. Should hold a lot of weight as long as frame is solid. You think?
