NT Sharpener on sale again
Discussion in 'Chainsaws and Power Equipment' started by Jutt, Oct 3, 2014.
  1. Chvymn99
    Cool, It should cover me than. Thanks.
  2. Machria
    Machria
    Long Island, NY
    The stone bits that come with the attachment ground down to be useless after just one or two uses. BUT, the below diamond replacements have lasted me all season. And I don't mean all 5 of them, I mean ONE BIT, lasted me all last winter. In the spring, I finally threw the bit away, and grabbed a 2nd one. Can't beat it for $10. ;)
    Get these if you have a 3/16" chain:
    http://www.amazon.com/Anytime-Tools...2623007&sr=8-2&keywords=diamond+chainsaw+bits
    Get these if you have a 5/32" chain:
    http://www.amazon.com/Anytime-Tools...2623007&sr=8-1&keywords=diamond+chainsaw+bits
    I guess if you stick the bit into the cutter and hold it there, you can easily grind off way to much. But I just stick it in, and pull it out 2 or 3 times for each tooth. I kind of get into a rhythm, and just push in and out while counting to myself in a cadence: i.e. "One .. two.. three..." where each number is when the bit was slid thru the cutter. I use the same tension as I go along, just a light pressure toward the cutter. It takes 2 or 3 minutes on each side of the chain. I'm 100% sure my chains are not nearly as precise as these professionals using grinders, but they come out super sharp and seem to last longer than when I was hand sharpening with a file. I always read here to only go one direction... but that never seems to work for me. Once I get the bit onto the cutter, I find it best not to lift it away until the cutter is done. That is why I do the one-two-three count, each tooth gets the same grind.
    I can't quite grasp how the grinder actually works? Are the wheels used very thin, and rounded on the end? In the pictures of them they seem to go into the chain on an angle, but how do you make sure the cutter is in the right place and you don't just grind off the top of the cutter? Is there some sort of stop for each tooth to hit / line or something??
    BillinTX and Sinngetreu like this.
  3. Hedgerow
    Hedgerow
    SW Missouri
    The indexing pawl slips in behind the cutter... Then you lock the chain down..
    I too, ordered one of these grinders to have a second to go with the Silvey and CBN wheel...
    Plus, it has a light on it...
  4. Machria
    Machria
    Long Island, NY
    ok, thanks. So does that kinda make it "idiot" proof? Meaning once you lock it down, you just drop the wheel down and grind, or do you still need to be "precise/coordinated" to make a good cut?
  5. Hedgerow
    Hedgerow
    SW Missouri
    Idiot proof in some aspects.... But if not set up properly, can still do a less than stellar job... But yes, the control is better...
    Although I too like those diamond bits you refer to for quick touch ups... They do a very nice job if you're careful...
    And hold their shape!!
    DexterDay likes this.
  6. Machria
    Machria
    Long Island, NY
  7. Hedgerow
    Hedgerow
    SW Missouri
    Yeah... That one's pretty awful... But you could get a chain sharp with it... Probably... If ya knew what you were doing...
  8. CTYank
    CTYank
    CT Panhandle
    Try a 1/8" wheel for 3/8" LP and .325" chains.
    clemsonfor likes this.
  9. redneckdan
    redneckdan
    Northern Minnesota
    Took delivery of my NT sharpener yesterday. Got it assembled and mounted up today.
    To be totally up front...I am not impressed...
    First thing I noticed, the hole in the shaft is not threaded parallel and concentric to the shaft. I didn't even bother throwing a dial indicator on it, it was that bad. I stripped the motor and will clean it up at work to make it useable.
    Plastic scatter shield does not even come close to fitting properly.
    Vise is not centered under wheel and lacks sufficient adjustment to center it.
    That is all I have found so far. I bought it for the sole purpose of grinding depth guides. I think it will work for such tasks once I get it straightened out. I would not use my particular machine for grinding teeth. Glad I went with the 511 for my first machine. YMMV...
  10. HDRock
    The one I bought Northern Tool is no longer available(Item #193020 is no longer available), http://www.northerntool.com/shop/tools/product_200327449_200327449
    whether or not the one you have is made by the same company just a different color and renamed, I don't know.
    It looks the same but is it
  11. Chvymn99
    Mmmm..... That's not good... I was going to the store & buy one today. Do you think it's just that particular machine or that model itself?
  12. HDRock
    Well Nate got a bad timber tuff ,it fell apart ,he got it replaced and the new one is fine
    Plastic scatter shield didn't fit good on mine either but I got it to fit , that's the only thing I found a problem with
    clemsonfor and Chvymn99 like this.
  13. redneckdan
    redneckdan
    Northern Minnesota
    Since you have a store locally I would give it a shot. You can always return it. I had to mail order.
    In reality, I am pizzing and moaning an awful lot considering it cost less than a third of what my other grinder cost. For what I bought it to do, I think it will work.
    MasterMech, DexterDay and Chvymn99 like this.
  14. MasterMech
    I think you nailed it Dan. It's the best grinder you can buy for around $100. Beats the snot outta the plastic grinders and somebody who knows machinery could tweak one into a pretty decent grinder indeed.
    But it's not a $300 511 even tho that's the machine it copies, and sure as heck isn't on the same level as my USG.
    HDRock and Chvymn99 like this.
  15. Chvymn99
    Well, I bought one. I put it together, and promptly started sharpening. A little different than the other one I have (Foley Belshaw) I can't say that I'm proficient with either. But I know that it's still sharp after a tank though pin oak. I'm happy that I can now sharpen my own chains. My biggest issue with both is how the heck to adjust the stop for consistant cuts. I was always having to tweak to either get on it or back off it a bit. I guess that's a learning curve. But it seem pretty decent for firewood cutting.
    clemsonfor, HDRock and DexterDay like this.
  16. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Anybody know what the rectangular stone is for? Maybe for dressing the grinding wheels?
    Gary
    clemsonfor, HDRock and Chvymn99 like this.
  17. Chvymn99
    Thats what the video showed anyways...
  18. redneckdan
    redneckdan
    Northern Minnesota
    Yes for dressing the wheel.
    Which brings another point, I didn't get one....grrrrr......
  19. HDRock
  20. Gary_602z
    Gary_602z
    Thanks HD! Should get me going, wish me luck!:)
    Gary
    Chvymn99 and HDRock like this.
