Now that we have On Demand DHW we need On Command?
Discussion in 'The DIY Room' started by don2222, Feb 11, 2019.
  1. don2222
    don2222
    Salem NH
    Hello
    The delivery of On Demand is a longer wait! So now they have On Command for the On Demand!
    On Command is the recirculating pump that you put under the sink with the special motion sensor so when you are near it goes into action and brings up the hot water in the hot water pipe by dumping the water in the cold water pipe so no water is wasted and the water is nice and hot as soon as you turn on the faucet!
    Taco makes a good pump for over $400 and the special motion sensor for under $100!
    That costs as much as my big On Deman Panel!!
    What about a cheap under sink On Demand? Would that do what the On Command does?
    See
    On Command
    Motion sensor for On Command
    What about another under sink On Demand?
    https://www.walmart.com/ip/Waste-Ki...MI9cup_fm04AIVXVgNCh2bggAmEAQYCSABEgL_YPD_BwE
  2. TurboDiesel
    Hi Don
    I just have the EcoSmart tankless water heater.
    I have read a little about the motion activated hot water recirc. pumps but dont really see the need for my small house. All my plumbing is in a 20' area all at the back wall of my house. It does take a while for the hot water to get to faucets though. So it does waste a little water waiting, but i'm on a well.
    I've also thought about preheating water in a storage tank before the water heater just to bring it up to temp faster, but it would be a pretty big expense for the small gain.
    I've thought about the new evacuated solar systems for preheating a storage tank, but again, the expense seems high...and the sun hasn't shined in 8 months here.
  3. In the Pines
    In the Pines
    If you plumb correctly you could potentially do just a gravity fed recirculation system. You need "x" amount of feet do that though. Since cold water is denser, is sinks and flows back to the tank. I've heard it works for standard hot water tanks, no idea about on demand.
  4. TurboDiesel
    I can believe that with a tank type heater but the EcoSmart has a flow sensor with a little paddle wheel that needs to spin to sense flow, checks inflow and out flow temps, then it will fire the elements.
  5. don2222
    don2222
    Salem NH
    Rachel’s Problem all began after she had an On Demand DHW Panel Installed
    See Rich thetheway!
    Here is R.T. Again!
    TurboDiesel likes this.
  6. don2222
    don2222
    Salem NH
    This recirc system is really cool!!!
    This is cool because you can do additional sinks with a $40 add on kit!
  7. TurboDiesel
    . Do not use with tankless water heaters.
  8. don2222
    don2222
    Salem NH
    why???
  9. TurboDiesel
    IDK but its in the specs...
    • WATTS HOT WATER RECIRCULATING SYSTEM: The Kit Includes: Pump with timer, 2 adapters with rubber washers, valve mounting screws, sensor valve, two 12-inch supply lines
    • RECIRCULATING PUMP WITH TIMER: 24-hour programmable timer activates pump when you need it. And it is extremely quiet compared to other system in the market - no vibrations. Do not use with tankless water heaters. Insert the 115V plug on the line cord from the pump into a properly grounded 115V outlet
  10. don2222
    don2222
    Salem NH
    Oh well
    The system that Richard Thetheway Installed was an a Gas tankless Hot Water Panel for Racheal in the vid above!
  11. don2222
    don2222
    Salem NH
    Hey Turbo
    Just found this to use with my eco Smartie Panel
    It is made to work with it for only $176.00 Buckos!
  12. TurboDiesel
    that looks interesting!
  13. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    TurboDiesel do you have any experience with any of the leak detector systems that shut off the water? I have a finished basement and would like to install one. Thanks.
  14. DBH
    DBH Banned
    Downeast, Maine
    Our Rinnai tankless has been trouble free for 12 years. Maintenance is a vinegar flush once a year to clean out the piping.
    So you can't wait maybe 30 seconds for hot water ? What gives ? :faint:
    Like the idea of a leak detector in the system. The one we have on the floor in the utility room is a simple battery unit.
  15. don2222
    don2222
    Salem NH
    Electric takes about a minute to warm up, is yours gas?
  16. DBH
    DBH Banned
    Downeast, Maine
    LP...furthest outlet takes only +/- 30 seconds to heat.
