November bag count ?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by PoolguyinCT, Dec 1, 2014.
  1. jtakeman
    They shut down in low demands. Then restart when the stat calls for heat. Most of the pellet stoves have built in igniters that start the fuel for ya. No manual starting required. ;)
    Tips,
    1.) Look for one that has high/low setting. Once the warm days are over(spring/fall shoulders). The stove will go to a maintenance fire and help reduce ware on the igniter.
    2.)Try to stay on the larger size and don't go too small. Depending on what your heating. Might want to look at the whole house furnace route.
    3.) At least consider a multifuel stove. One that will eat fuels besides pellets. They generally tend to be more forgiving on pellet quality. Or as we say not pellet picky. Generally the bottom feeders or units with self cleaning burnpots are more pellet friendly.
    My chainsaws have become shelf queens. I haven't started them since the 06' ice storm. Just can't bring myself to sell em off. I do hug them every now and again!! ;)
  2. briansol
    briansol
    ct
    I had a similar situation, i had a 1.5 hour commute each way and 9 hour days when i was looking to get off oil. I wanted wood, but of course, it wouldn't last all day without a feed. So, that's how i ended up with a pellet stove. I could dump a bag and it would still be on when i got home on all but the highest setting.
    Now it should also be stated that 55lbs is weight, not volume. I have a 55 lb hopper in my stove. Sometimes I can fit a bag and a half in there of some brands (60 lbs) Sometimes one is almost to the brim. it really depends on the brand, and more so the air space left from the pour. longer pellets will take more space.
    I generally top off in the morning and turn down to setting 2. I come home for dinner and turn it up to 3 for the night. before bed, i top it off again. I gave up on thermostats, too much power cycling even with high-swing. Frankly, it's not needed in winter so much as it is in the fall/spring when it gets too hot, not too cold in the house.
    will711 and IHATEPROPANE like this.
  3. Freakingstang
    Freakingstang
    Thanks guys. I had never thought or looked at pellet stoves til I read this thread. Thanks for answering my questions!
    will711, jtakeman and brokenwing like this.
  4. jtakeman
    Stop in anytime, That's what where here for! :)
    brokenwing likes this.
  5. Freakingstang
    Freakingstang
    That's my issue... Oil heat and 10-12 hour work days with commutes from 1/2 hour to four hours. The trips to buffalo and back are always fun as there is just 8hrs in drive time. I can get 10 hour burn times now, but it depends on how early I get up to get the stove roaring and loaded up for the day ahead and the wood used. And even in long days I usually have enough coals buried in the ash to restart it fairly quickly but the house has a chill when I get home
    Sounds like this could be a good alternative to 4$ a gallon oil. Price is down now, but still...
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    We are? I thought we are here because, now what was the reason again?
    jtakeman likes this.
  7. jtakeman
    I thought it was because they always speak of beer in the pellet room! ;)
    will711 likes this.
  8. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    You sure? I thought it was because we .... oh darn forgot again.
    Likely you are correct.
  9. jtakeman
    What were we talking about?
    SmokeyTheBear likes this.
  10. IHATEPROPANE
    IHATEPROPANE
    :drunk:
    will711, jtakeman and SmokeyTheBear like this.
  11. jtakeman
    Thanks IHP, We need a youngin to keep tabs on us old fort's! ;)
    SmokeyTheBear and IHATEPROPANE like this.
  12. briansol
    briansol
    ct
    Yup, it works out good.
    I'd suggest leaving your wood stove as is, and doing a direct vent pellet in another room/opposite side of the house/etc and plan to run both or either or depending on day/situation/coldness etc.
    Now, if we could just try to convince you to ditch the mustang :D jp
  13. mithesaint
    mithesaint
    NW Ohio
    Screw the free standing stove. Get a pellet furnace. Watch for a used one on craigslist, hook it up to the duct work with appropriate dampers, and off you go. The noise from the fans and the dust from pouring pellets and cleaning the stove is in your basement, not your living room.
    I have a St. Croix SCF 050 in my basement that's hooked up to my duct work. It's currently burning shelled corn, and the corn cost me $125 per ton. The whole house is toasty warm. It's a bit undersized for my house, but it's nice for now. I intend to get a St. Croix Revolution as soon as I can find one. They're not common, and not being manufactured this year. I also have a Englander 10-CPM in my living area. It carried the majority of the heating load the past few years but it's the backup unit now. It's nice because it's a multifuel stove with high/low AND on/off capability. I get a lot of solar gain if the sun is out, so the CPM is in on/off mode for most of the time, unless it's really cold.
  14. jtakeman
    Hard to beat the whole house warmth a furnace would provide.
    IHATEPROPANE likes this.
  15. briansol
    briansol
    ct
    not everyone with oil has forced air. i have radiators.
    Further, most locales won't allow solid fuel as a primary heat source for CertOc. A pellet furnace is a nice thing, and i'd want to have one myself, but only if my house was outfitting with the ducting already, and had, say, electric baseboards to qualify as primary heat source.
  16. jtakeman
    Its actually easier to sister in a pellet boiler than most think. No need for draft dampers like the forced air furnaces. A few solenoid's is all that is required and the Primary is still the oil furnace. Pellet would be the secondary!
  17. briansol
    briansol
    ct
    Perhaps, but i know I couldn't do it. 1 flu, 1 device. I have my oil boiler in it. the other flu is for the fireplace (that my insert sits in and doesn't go all the way to the basement anyway) Perhaps my set up is a little unique in that regard.
  18. imacman
    imacman
    Denver, NC
    I WISH I could find one that cheap to buy. :headbang:
  19. subsailor
    subsailor
    Winthrop, Maine
    In Maine it's now legal to have a oil furnace AND a woodstove/pellet stove in the same flue as long as the chimney is lined. That's what I'm doing with my second stove.
    imacman likes this.
  20. Freakingstang
    Freakingstang
    This was the whole reason I did an insert, because I don't have a second flue in my chimney for a wood furnace in the basement.. that would be ideal for me with a huge storm door to chuck wood down there. I'll check codes here about a pellet stove in the same chimney as the oil furnace, but I don't think it sounds kosher here.. I could be wrong, in that case that would be a fairly easy solution..
