Noodling chain death
Discussion in 'Chainsaws and Power Equipment' started by Andy8850, Jul 5, 2019.
  1. buZZsaw BRAD
    Noodle parallel to the grain with bark on ground. Sawdust looks like noodles. With chain nice and sharp it should cut easily.
  2. huskihl
    huskihl
    What you did was milling. That’s why they recommend 90+cc for that. It leaves all fine powder and requires more power to make the saw cut. Cutting lengthwise with the log is much easier and leaves long noodles
  3. amateur cutter
    To noodle efficiently, the bar needs to be longer than the log, in my case 24". Keep the bar tip down, power head up & let the saw work through about 3/4 of the way on the tip end then lower the power head end. Clears the fibers better that way ime. The more saw you have the better.
  4. brenndatomu
    I don't noodle a ton, but I have never had premature dulling when doing it...in fact just the opposite...the chain seems to hold its edge longer...
  5. tamarack
    tamarack
    paulina oregon
    I've never noticed any difference in chains going dull when noodling. It's all in what abrasive material you are hitting with the chain. A tip for anyone new to cutting firewood, is always look at the log/ round your to make your cut in and remove the dirt. Anything that's been skidded will always have more dirt and rocks in it.
  6. Lastmohecken
    Lastmohecken
    Arkansas
    That's pretty much the way I do it too. Usually cutting 16 to 18" with 24/25" bar.
