Noobie need help
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by michaelangelocioffi, Jan 19, 2019.
  1. billb3
    It's tough to use a coal stove to burn wood.
    I've done it and had some pretty wild fires and had to sit pretty close to the stove as most of the heat went up. Was in a uninsulated shed and was pretty much a campfire in a metal box. My brother used to sit next to it with his CB radio doing skipland stuff at night.
    I'd look around for a used airtight wood stove if you're serious about some heat.
    But a rope gasket on the door to see if you can get a little more heat out of it might be worth it.
    Chaz, mat60 and raybonz like this.
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    Chaz and mat60 like this.
