Non Ethanol 87 or Ethanol 89
Discussion in 'Chainsaws and Power Equipment' started by zmccart2, Jan 12, 2015.
  1. zmccart2
    zmccart2
    Northern Virginia
    What is the better choice for my MS310 and other small engines? Gas station just a few minutes away sells the 87 non ethanol or should I stick with the 89 that contains ethanol.
    I will run the 87 non ethanol through generator for sure but not sure what is the gooder option for the 2 cycle saw and weedeater. Input?
    Pallet Pete likes this.
  2. tuneighty
    tuneighty
    South Central PA
    If it were me, I would choose NON ethanol every time!!
  3. JustWood
    JustWood Guest
    Alcohol dissolves 2 stroke oil.
    Think ,,,, plowing a bucket of KFC chicken,,,,,, when yur done you use one of those alcohol wipes to majixLEE get all the fryer oil and chicken grease of yur hands.
    PullinMyPoulan and XXL like this.
  4. XXL
    XXL
    Ontario, Canada
    x2
    PullinMyPoulan and tuneighty like this.
  5. Horkn
    I used to think that years ago, but about 20 years of of using e-10, regardless of 87, 89, or 91/2/3 octane, in everything from premix 2 strokes, oil injected 2strokes, and all sorts of small and large 4 strokes, has me knowing there really isn't a difference as fuel system parts eventually need to be changed anyway. Jm2¢
  6. lukem
    I have a station that sells 90 octane non-E fuel. I try to use it every time, but the station has weird hours and is a bit out of the way. I would buy that every time if i could.
    XXL likes this.
  7. XXL
    XXL
    Ontario, Canada
  8. mdavlee
    mdavlee
    87 e free is what I run with 89 and 93 available e free also.
    clemsonfor, XXL and Sunfish like this.
  9. bigbarf48
    bigbarf48
    Stone Mountain, GA
    If non ethanol is available, why not run that?
    clemsonfor, Drvn4wood and XXL like this.
  10. Sunfish
    Sunfish
    Success Mo
    I'd go with the 87 E-Free...
    PullinMyPoulan, XXL and mdavlee like this.
  11. prell 73
    prell 73
    ia
    Always e free.
    XXL, Sunfish and tuneighty like this.
  12. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I run 110 non ethanol leaded fuel and my saws dig it… I run everything else on 87 non ethanol and have had zero carb issues with any of it since. The beauty of 110 is it has something insane like a 7 YEAR SHELF LIFE! :D Ok I'm a bit eccentric but…… :whistle: Im not sure what 87 non ethanol has for a shelf life on paper but I have used it after 12 month sitting with no issue at all. :dex:
    XXL likes this.
  13. prell 73
    prell 73
    ia
    So u are run in av gas did u have to retune the carb I was thinking about runin av gas but I don't what to hurt my saw.
    XXL likes this.
  14. XXL
    XXL
    Ontario, Canada
    Used to be able to get Av gas from a friend here too. Saws ran great on the high test leaded fuel:dex:
    tuneighty and Pallet Pete like this.
  15. Pallet Pete
    Ovid
    Just don't huff the exhaust!:saw::saw::saw::saw::hair:
  16. tuneighty
    tuneighty
    South Central PA
    When I could get E Free, and ran my Civic to work (about 45 miles per day.) It was the difference between filling up once per week (efree) to filling up twice per week (Ethanol added.) It easily made sense to pay the extra (at that time it was $4.25/gallon, around $.50 more per gallon.)
  17. Osage Orange
    Osage Orange
    So you got twice the gas mileage with E free?
  18. Horkn
    IME, and what most people see, it's maybe a 10% at most lower mpg with e10.
    Yes, if you can get ethanol free, by all means, buy it. Just remember that it may not actually be ethanol free. The gas stations have to take the gas that's on the tanker, even if the station says they don't sell e10. Also. Mid grade gas is a mix of premium and regular on site. So, if regular is e10, midgrade has at least some ethanol.
  19. tuneighty
    tuneighty
    South Central PA
    I did inde, 1992 Honda Civic ... I miss that little car.
    Sorry, I worded that a bit confusing ... On E free I could fill up on Monday and it would last me until next Monday, on regular I had to fill up again by Friday...
  20. Osage Orange
    Osage Orange
    I am a fan of E10 but do use Efree in my saw mix only because I may have a jug mixed and unused during certain times of the year. I get Efree from a pump that has several different choices pumped through the same hose. Since I usually purchase two gallons at a time I often wonder if I get Efree or if I get the E10 from what's already in the hose and the next customer gets my Efree.
