Next chainsaw (?)
Discussion in 'Chainsaws and Power Equipment' started by dgeesaman, Nov 30, 2014.
  1. Cut4fun
    Cut4fun
    OHIO Redneck
  2. Cut4fun
    Cut4fun
    OHIO Redneck
  3. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
  4. cgraham1
    cgraham1
    Nor Cal
    These are from another site...
    "...all saws were emptied (oil tank flushed with mix) and the tanks blown dry. I also cleaned bw the CC and tanks with air."
  5. bassJAM
    bassJAM
    Cincinnati, OH
    Thanks for posting, very interesting. I've always wondered what my Makita weighed, there's so many conflicting weights out there. Good to see that 7900 on the scale, now I know.
  6. Freakingstang
    Freakingstang
    I always hate the weigh scale posts on other sites. Who cares what it weighs empty, no bar oil or no B/C... That doesn't tell you much, especially when each manufacture holds different amout of fluids. I don't take a Powhead to the woods and expect to cut anything without a bar, chain, fuel, or oil. Not unless its a MS362. SO like I said, in the real world the 365 and 372 old or new are the same weight. If 3 ounces make a difference to you or you can tell 3 ounces, then you have bigger issues than needing a new saw.
    bigbarf48, HoneyFuzz and mdavlee like this.
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Thats usually the same thing I say when I see empty weights as well ! Give me "usable" weight..now we are talkin :)
  8. bassJAM
    bassJAM
    Cincinnati, OH
    Meh, the empty weight evens the playing field on specs. It's pretty typical to see that listed with a lot of things running by motor. I've heard older guys say they only fill up the bar oil and fuel tanks half way to save weight on their saws too. And my Dolkita sure has a different weight when the 20" bar is on it vs the 28".
  9. bogydave
    Husqy 359, 20" oregon pro lite
    Power head specs : 12.1
  10. MasterMech
    I would agree that the "loaded" weight is more of a real world figure but the dry weights are useful/interesting as well. Best to be well informed.
  11. the GOAT
    the GOAT Banned
    Maine
    Did the awesome ms362!!!! break everyone's scales?
    SquareFile likes this.
  12. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    :thumbs: I'll take My Makita 6401 converted to the 79cc to the woods everytime don't leave home without it.
    mdavlee likes this.
  13. dgeesaman
    dgeesaman
    Elizabethtown, PA
    It's perfectly accurate to calculated loaded weight from dry weight and tank capacities. I'll happily take dry weight, IF it's an accurate number.
    A fluid ounce of fuel weighs around .05 lb. A fluid ounce of oil weighs around .06 lb. With a dry weight you can figure the weight with tanks half-full, completely full, etc.
    David
  14. MasterMech
    That's a pretty big if considering the discrepancies that pop up between actual weights and specs. Assuming you could fill the tanks to 100% capacity, and the listed capacities were accurate, you could arrive at an accurate weight by using your method in reverse. Weigh the saw ready to go and subtract the weight of the fluids to get your actual dry weight.
  15. SquareFile
    SquareFile
    somewhere
    My head hurts
  16. Chvymn99
    Mine too, but mines from stress from work....:picard:
