Newby questions about venting
Discussion in 'Modern EPA Stoves and Fireplaces' started by bushpilot, Oct 17, 2015.
  1. bushpilot
    bushpilot
    Eastern Washington
    My woodstove sits in the corner of my living room, which has a vaulted ceiling. Above the woodstove, the ceiling is about 9 feet high, in the center of the room it is about 12-13 feet (haven't measured). Currently the stove vents straight up through the ceiling and roof, and there is about 6 feet of chmney above the roof.
    Every bit of that is up for grabs when I install the 30-NC in the spring. I can easily place the stove more towards the center of the room (the peak of the ceiling), or I can leave where it is. I can go up through the ceiling, or I can vent through the wall on the low side. Whatever is done will be done with all new supervent components, nothing will be salvaged of what I have.
    So - what would you do? Matching the current install configuration is simplest, but while I am doing it, I would rather go for "long term easy" rather than short term gratification. So here are the three thoughts, listed in assumed order of simplest to most difficult.
    1. Leave where is, vent through ceiling. The only issue I see is that it is a little hard to clean the chimney because if its required height above the roof.
    2. Move to center, longer stovepipe in house, shorter chimney outside. I believe this will give me a little more heat in the house (off the stovepipe), and it certainly would give me a shorter chimney for easier cleaning.
    3. Leave where is, vent through wall. No idea of advantages or disadvantages. I am sre it will cost more, and I cannot think of any advantages, but there might be something. I can't imagine how I would get up there to clean the chimney (it would be on the low side of the roof, and would stick up at 7-8 feet above the roof in oder to get the 15 foot min height), but am wondering if one can clean from the bottom? This idea seems crazy, but then again I am a newby at installs. How is the horizontal secction cleaned, and the short vertical stovepipe before the bend?
    I am favoring option #2 for reasons stated, what would you do and why? Thanks in advance!
    Greg
    wildwest likes this.
  2. KaptJaq
    KaptJaq
    Long Island, NY
    Some pictures would be nice to get a better idea of layouts. I like the idea of moving to the center of the room. Cleaning up from the stove is not that bad, just takes a little set-up time so the dust is contained.
    Good luck with the new install,
    KaptJaq
  3. wildwest
    Wyoming high plains
    agree because (non technical)
    Pipe at my previous home was chest high to me on the roof. PITA to sweep.
  4. concretegrazer
    concretegrazer
    Southwest MO
    I like #2. Easier to clean, no chimney braces on the roof, and less cost.
    fox9988 and wildwest like this.
  5. papadave
    I'd go for door #2.
    The pipe is less expensive if you use single wall, and the amount of pipe outside is less, so the exhaust should stay warmer, longer. I used to have icicles (brown ones) hanging from the cap......not so much with the 30 setup.
    You'll maybe have to experiment a little to see if the suggested 15' minimum is sufficient. It wasn't here, and I still have a little smoke rollout even at 16'.
    I've been thinking of getting a Sooteater, to clean from inside, but it's not a huge deal to get to the cap outside......yet.:BrianK:
  6. bushpilot
    bushpilot
    Eastern Washington
    Oops, I forgot about the OAK. Option #2 would not put the stove on an outside wall. To get outside air, I would have to go in the wall, then 8 feet up into the attic of the room adjacent, then 12 feet to an outside wall. That is 20 ft of vent, 2 90 degree elbows, and the opening would be about 9 feet above the ground.
    If I "oversize" the venting in the wall and attic, would it vent?
    Greg
  7. papadave
    You probably don't really "need" an OAK.
  8. bushpilot
    bushpilot
    Eastern Washington
    True, but it is required in WA state.
    Greg
    papadave and wildwest like this.
  9. papadave
    Ahhh.
    Well then, I guess you do need one.:)
    Now, back to your options.......
  10. bushpilot
    bushpilot
    Eastern Washington
    I saw a mention somewhere about stovepipe that also serves as an outside air source. I cannot find details as to who sells it, the cost, etc. anyone know anything of that?
    Greg
  11. wildwest
    Wyoming high plains
    Thimble with OAK?
  12. bushpilot
    bushpilot
    Eastern Washington
    The plot thickens - WA code requires ...
    A source from outside the structure of primary combustion air, connected to the appliance as per manufacturer's specification. The air inlet shall originate at a point below the fire box. The duct shall be 4 inches or greater in diameter, not exceed 20 feet in length, and be installed as per manufacturer's instructions ...
    So, I cannot have an air inlet above the firebox, which eliminates several creative solutions I was considering. The 4 inch duct is interesting, as the outlet on the firebox is 3 inches, if I am not mistaken (I have not looked to verify).
    Still pondering ...
    Greg
  13. bushpilot
    bushpilot
    Eastern Washington
    I tried to take some pictures, but they were not clear enough to clarify anything.
    Greg
  14. papadave
    My Class A is about 7' out the peak. When I clean, I remove the 3' top section and cap as one.
    Can I presume the existing placement is on an outside wall? If so, there's the best solution to the OAK requirement.
    If you wanted to clean from the bottom in that scenario, just pull the stove pipe, and use a Sooteater from the bottom.
    bushpilot and wildwest like this.
  15. bushpilot
    bushpilot
    Eastern Washington
    I contacted Englander about my crazy venting thoughts, they were not too keen on them. :faint:
    Greg
    Edit - this means the combustion air, I did not ask them anything about the exhaust.
  16. bushpilot
    bushpilot
    Eastern Washington
    Supervent, Duravent, or other? How difficult is it to separate sections? Any chance of breaking them or wearing out the attachments by repeatedly separating them?
    Greg
    wildwest and papadave like this.
  17. Backwoods Savage
    Greg, those words, "As per manufacturer's specification." Ah, that could very well be an out for you if the manufacturer does not require it, then you should not need it.
  18. papadave
    Supervent. They twistlock, and don't always like to come apart easily.
    I've had this setup since 2009, I think, and no problem with wear. If you bend the connection in some way, you might have a problem.
  19. bushpilot
    bushpilot
    Eastern Washington
    Yeah, but the kit does exist for the stove, made by the manufacturer.
  20. bushpilot
    bushpilot
    Eastern Washington
