Newbie saying Hi
Discussion in 'The Wood Pile' started by Paul Booth, Jan 7, 2019.
  1. Paul Booth
    Paul Booth
    MN
    Last one I hope... "noodle" you got me there?
    Rope, Chvymn99, mat60 and 11 others like this.
  2. Ashwatcher
    Ashwatcher
    West By God Viginia
    Paul Booth - Cutting large rounds vertically or otherwise to make them manageable to haul, lift or fit the splitter-Love the kitty
  3. Locust Post
    Noodling is when you cut down through a big round from the top or the end like where the splitter would hit. You might do that to be able to get the size more manageable.
    Rope, Chvymn99, Paul Booth and 7 others like this.
  4. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
  5. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Sometimes I have to noodle large rounds if I can’t split them with my Fiskars ISO Core.
    Rope, brenndatomu, Chvymn99 and 7 others like this.
  6. Canadian border VT
    CAT is also used as a short way of saying catalytic converter, which are used in some high efficiency EPA stoves.
    Rope, brenndatomu, Chvymn99 and 6 others like this.
  7. TurboDiesel
  8. Midwinter
    Rope, brenndatomu, Chvymn99 and 4 others like this.
  9. Backwoods Savage
    Greetings Paul Booth and welcome to the forum.
    I apologize for checking in late but I was out of town. It sounds like you will fit in here very nicely. If you have some time, here is some good reading material that might help you: Primer on Woodburning by Backwoods Savage
    Chvymn99, Paul Booth, Chaz and 3 others like this.
  10. Greg
    Greg
    Welcome aboard. You will like hanging out around here.
  11. Paul Booth
    Paul Booth
    MN
    Well I have something to read tonight thank you Backwoods Savage!
    Thanks guys for the help on the nomenclature I'll have it down soon.
    Here's a couple shots of the splitter. It's an oldie but it's a goodie. This summer I am going to do a little bit of work to it. I'm going to repower it with a 13hp and replace all the hyd lines.
  12. Paul Booth
    Paul Booth
    MN
    It's not exactly OSHA compliant but I'm not complaining it works well. I may even give her a coat of paint... 20190110_151330.jpg
  13. Ashwatcher
    Ashwatcher
    West By God Viginia
    Wow! Paul Booth thats postcard material, (or its modern day equivalent?) right there sir. It’s like you’ve been here all along. Racking up some major FHC cred here for sure! Hoard on my friend:dex:
  14. Ou812
    Ou812
    Eastern ct
    I love the tongs and winch! My back is jealous right now.
  15. Backwoods Savage
    Looks good Paul. The only exception is that it appears you need to reposition where the end of the boom is as it appears you have to pull or push the log back toward the splitter to set it down. Doesn't need much. Still looks great.
    Ou812 and Chaz like this.
  16. Paul Booth
    Paul Booth
    MN
    You are correct but if I boom up a little it lands nicely.
    By the way that was a great read thank you for that.
  17. Backwoods Savage
    You are welcome. I wondered if you could adjust the boom a bit. Looks good.
    Paul Booth likes this.
