Newbie... Need Install Advice For Farenheit Endurance
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Triple A Arsenal, Sep 25, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    Yep. If you have 2 holes, you were delivered an old unit. If it's a single hole, it's a newer unit..
    I wouldn't ask a question if it didn't lead to an answer. I was going to tell you once you answered the question. ;)
    The last person on the forum who bought one, had an older unit delivered. She called Fahrenheit and told them that she paid $X,XXX dollars for a new stove, and was given a unto that was 3-4 years old (several upgrades done since then). Fahrenheit delivered a new stove to her location. She had hers hooked up for over a week and was experiencing problems as well. It wasn't burning properly, couldn't heat her home, etc..
    You paid a lot of money for a new stove. I'd make sure I got a new one.
    On the back of the stove is a serial #. It is on the metal tag. Can you tell me what the number of that is also?
    Thanks..
  2. smoke show
    smoke show
    Pittsfield, Wi
    speaking of Sarah. where'd she go?
    wildwest likes this.
  3. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Can you guys tell me quickly if FIRESIDE ULTRA premium grade pellets any good? $249 a ton
  4. imacman
    imacman
    Denver, NC
    FU's are a good pellet.
  5. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Thanks!!! Was able to score some while picking up come concrete blocks.
    imacman likes this.
  6. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Don't mind me Dex, I am asking lots of questions, you guys are full of knowledge! image.jpg This is the inside behind the ash pan.
  7. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    So got another :ups:
    The stove adapter is suppose to go on the furnace correct? Because it doesn't fit, unless I need another peice?
  8. DexterDay
    Northeast Oh
    It will be a snug fit. I have the same brand and it goes on. But you have to twist it on.
  9. DexterDay
    Northeast Oh
    She was going through a rough patch the last I heard. She will make it and be alright. I can see her logging in when it gets colder and is inside more.
    smoke show likes this.
  10. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    It goes on the inside right? Did you attach with screws?
  11. DexterDay
    Northeast Oh
    Make sure Inner diameter of the the adapter, goes over the outer diameter. It should slip over the exhaust snout on the furnace.
  12. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Ok, it's a close fit. I'll try when I am ready. Some high temp sealant should do the trick. Gonna try to run the exhaust this weekend. I did notice the fresh air inlet is VERY close to the exhaust. There is also a damper installed with a lever?
  13. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    I am placing an order through Home Depot for the supply and return duct work. I just realized in the manual it says 10" outlet, then return air supply should be 10% LARGER?
    What size hole is on the cold air box that attaches to the furnace?
  14. DexterDay
    Northeast Oh
    10" is the return side. I believe as long as your cold air return on your house is 10% larger, then you are o.k. Otherwise Fahrenheit should have made a 11"-12" hole on the Cold air return box.
    And yes. The intake is very close and it's a tight fit to get the OAK flex vent attached properly and still have a functional intake damper (if installed to far on intake, the lever will not move and you can not adjust the air flow through the furnace for burn air).
    343amc likes this.
  15. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Started the vent install today, it's going but a slow process.
    DexterDay, 343amc and smoke show like this.
  16. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    smoke show, DexterDay and 343amc like this.
  17. 343amc
    343amc
    Northeast Lower Michigan
    That can't be fun going through a poured wall. I'd guess it's :drunk:time after doing that.
    imacman and DexterDay like this.
  18. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    You know it, 10" solid thick!
  19. smoke show
    smoke show
    Pittsfield, Wi
  20. eatonpcat
    Hope you miss the rebar!!:D
    imacman likes this.
