Newbie... Need Install Advice For Farenheit Endurance
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Triple A Arsenal, Sep 25, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    Through Fahrenheit directly
    If your inspection panel let's you clean the combustion blower? Then you shouldn't need to get in the back of the furnace very often.
    I did the same as 343 for awhile (kept a few screws out), but now I have just left it off.
    ivanhoe and Triple A Arsenal like this.
  2. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Found this with stuff that came with furnace.
    imacman, wildwest and ivanhoe like this.
  3. ivanhoe
    ivanhoe
    Northern Ontario
    I want one of those. Seen another manual Fahrenheit for sale and it went like a flash. I'll hold up for a automatic one, after seeing this it might take much longer for a recent one to pop up!
    343amc, wildwest and Triple A Arsenal like this.
  4. DexterDay
    Northeast Oh
    I removed what they call a "blade cover". That is a restriction in my opinion.
    But my furnace needed all the help it could get (as far as air flow) when I got it.
    ivanhoe likes this.
  5. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Gonna take a peak over the weekend and see what's behind door number 1......
    ivanhoe, 343amc and DexterDay like this.
  6. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    :ups::ups:
    I ordered a gasket for that cover and I recieved it......along with a hopper extension for some bad experience I had with my dealer!
    I'll have to check how to install since the hopper has a switch that is pressed when the lid is closed.
    ivanhoe likes this.
  7. DexterDay
    Northeast Oh
    Pretty sure you just jump the switch. Remove the back plate and unplug and install a jumper wire.
    ivanhoe likes this.
  8. DexterDay
    Northeast Oh
    My furnace is running now, I forgot to get those pics to you. Sorry. I will do it soon.
    ivanhoe likes this.
  9. mithesaint
    mithesaint
    NW Ohio
    Lol. Turned on mine tonight too. Thought I was done with it, but not yet.
    ivanhoe and DexterDay like this.
  10. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Matt emailed me the install instructions, the switch needs to be connected to itself to complete the circuit, easy enough. The back panel I think is blocked by cold air return.
    I put it on top to see about the height, looks like it will be very high to fill.
    ivanhoe likes this.
  11. DexterDay
    Northeast Oh
    You will have to remove that back panel to get to the switch and install the jumper. Your cold air return may be in the way, but once you remove it? Leave it off for future maintenance.
    The whole cold air return plenum that connects to the stove should be removed every year or every other to clean the distribution blower and lubricate it.
    And yeah, it's very tall with the extension. My Brother in Law (chbryson) has one on his Fahrenheit.
    ivanhoe likes this.
  12. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Really, remove cold air plenum? Wow ductwork is suppose to be a permant install. That sure does suck.
    ivanhoe likes this.
  13. DexterDay
    Northeast Oh
    Yeah, it does suck. Especially with a very nice install like yours.
    The blower needs cleaning and oiling. Much like your standard furnace needs maintenance (just accessible through a different area). And as noted above, that is where the 2 wires are for the hopper lid switch.
    Pellets are cheaper than Fuel oil and ProPain. But they come with a tad more involved maintenance schedule. The only motor on these that can be oiled is the large Distribution blower. And that is behind your cold air return plenum. I don't have my cold air return hooked up, but I also heat my basement with a wood stove (a lot of the time, but the last few weeks I have only had a couple fires). The furnace still does a great job, even though the basement may be 54°.
    ivanhoe likes this.
  14. 343amc
    343amc
    Northeast Lower Michigan
    I cheated when I put mine together. i put a start collar on the house cold air return. The 10" round duct slides over the start collar but the round duct isn't screwed to the collar.
    There is another start collar on the plenum side, but I bent the 'fingers' back so it isn't fixed to the plenum. It just keeps the duct from falling into the return plenun. The round duct is a tight fit, but I can give it a bit of a shove and it pops right off the furnace return plenum. Take off the plenum, do what needs doing, put it back on, slide the return duct on, job done.
    It takes about 30 seconds to remove and reinstall the cold air return when necessary.
  15. ivanhoe
    ivanhoe
    Northern Ontario
    We do our best to accommodate future inspections & cleanings in our crafty installations. Gotta be innovative at times to make life easier. Take for a instance; my exhaust cap on my DT-M vent, the tabs are slightly bent to able to easily remove for cleaning. I might replace with a big adjustable hose clamp if the collar is giving me fits down the road. Good point on the return plenum, will keep that in mind when I get around to finish mine.
    wildwest, DexterDay and smoke show like this.
  16. Flavy
    Flavy
    Pennsylvania
    Just bought my used F50 last month. In the process now of finishing the install, just need to get someone in to do the vent piping. Mine had the red led light control panel but was replaced for free by Fahrenheit because the red led control panels have been recalled.
    ivanhoe, DexterDay, jtakeman and 4 others like this.
  17. fox9988
    fox9988
    NW Arkansas 72717
    Welcome Flavy :handshake:
  18. will711
    will711
    Pocono Mts.
    Welcome to the show ,man where you at in PA?
    ivanhoe, DexterDay and wildwest like this.
  19. wildwest
    Nice to meet you :)
  20. jtakeman
    Welcome Flavy, Keep us posted on the install.
    Pic's too, We love those!! :D
