Newbie Hoarder seeks tree ID
Discussion in 'The Wood Pile' started by Daeven, Mar 18, 2021.
  1. Ronaldo
    Ronaldo
    The 4300 Qadra Fire. Is that a step top model? Those are really nice heaters from what I've heard.
    Sent from my SM-G930VL using Tapatalk
  2. Daeven
    Daeven
    Georgia
    It was fresh cut in Hall County - just across Lake Lanier from Forsyth.
  3. Daeven
    Daeven
    Georgia
    Compared to the oak and sweetgum I've split, this splits VERY easy, and is rather light.
  4. Daeven
    Daeven
    Georgia
    I'm right next to Hall County in west Jackson County.
  5. Ohio dave
    Ohio dave
    Akron, OH
    The bark looks like TOH, but TOH around here has yellowish wood.
  6. BuckeyeFootball
    BuckeyeFootball
    Mulberry. Bark and color of wood are off for TOH plus it smells like rotten peanut butter. I have alot of TOH and have cut a bunch.
    amateur cutter, Daeven, Horkn and 3 others like this.
  7. Chazsbetterhalf
    Chazsbetterhalf
    Welcome to FHC. You'll like it here. We like beer, dogs and pics. Lots of pics.
    This is some great reading material for starting out.
    Primer on Woodburning by Backwoods Savage
    Top left. Click on the 3 bars and select resource tab. You probably want to take a gander at some of the other reading material in here.
    Have a great day.
    amateur cutter, Daeven, Horkn and 2 others like this.
  8. Eric VW
    I guess bark can be different from region to region, but here in SW VA, mulberry bark can practically be mistaken for Osage.
    Here’s an internet pic of TOH bark Daeven -
  9. T.Jeff Veal
    Nice. I lived in Oakwood, worked in Gainesville about 3 yrs, back in the mid 80's. Drive up Hwy 53, go thru Braselton. Still go up that way sometimes
  10. Canadian border VT
    Welcome to the FHC Daeven :handshake:
    I’m no help in ID of southern woods..
    I have heard good things about Quadra fires..
    first stop buying wood from people that don’t what dry is.. a moisture meter in fresh split will tell you.
    2 it looks like tulip poplar to me. This is a light wood
    Which is a low btu wood
    3. All wood has same BTU per pound so until your better at identifying put light wood to use in fall spring and heavy wood like oak in January
  11. T.Jeff Veal
    On second thought, it's possibly catalpa. Had some this summer. I see some green/yellow on the edge of your split. What we had... 0831201018.jpg 0831201018a.jpg 0831201022.jpg
  12. Horkn
  13. BuckeyeFootball
    BuckeyeFootball
    The TOH bark looks like it has ridges but it really doesn't it just coloration, I have 2 in my front yard and about 10 across the street. Ive never dealt with Catalpa but after seeing that post it might be that.
  14. Daeven
    Daeven
    Georgia
    I've made a bunch of progress on my newbie hoard. My wood shed build was a bit backwards - I built a nice roof with less that acceptable walls and a floor that was little more than pallets. Then I put a bunch of firewood under that roof. I ended up removing most of the firewood, added the 4x4 posts, beefed up the side/back walls, added the lattice, reinforced the floor, added a middle wall, and then restacked the wood in an orderly fashion. The shed is 11.5 feet wide and 6 feet deep, and will hold 2.3 cords when full. A couple more trailer loads will fill it up, but I'm already thinking about building a cheaper wood storage system on the other end of the yard.
  15. Eric VW
  16. amateur cutter
    That's a nice looking woodshed for sure! Way to get after it.
    Chazsbetterhalf and T.Jeff Veal like this.
  17. Stoveshamster
    Stoveshamster
    Long Island north Shore
    Gorgeous
    T.Jeff Veal and Chazsbetterhalf like this.
  18. The Wood Wolverine
    Very nice wood shed! I'm a little late to the guessing game, but I've cut a few mulberry and I don't see that at all. It's yellow when fresh cut and ages to a red. If you fresh split it, you see yellow. Definitely don't see black walnut either. Never touched TOH. While the end and bark look like T.J.Veal's pic, the open split wood does not.
    90% sure, Tree of Heaven ID
    Oh, and welcome to FHC!
  19. Daeven
    Daeven
    Georgia
    Crap! The wood shed is full! Now what do I do? I recalculated the size, and it comes out to 3 cords including a bit of air space between the rows.
    I've been prowling Facebook Marketplace for free firewood and happened across a guy who cut a bunch of white oaks down on his property. They were already cut into nice logs, and he said I was the only one who followed through on showing up. It wasn't super close - 25 miles, but I made two trips. I pretty much filled up a 5x10 utility trailer with a 3500 pound axle. It worked out to being about 1/3 cord per load. I'm guessing it was a bit more than a ton of wood each. Along with the trailer, that was a bit much for a front wheel drive Lexus RX350, but it was very stable.
    The guy still has more wood, but without some work, I have no where to put it!
  20. buZZsaw BRAD
    Looks like there's plenty of room behind the shed, on the side of the shed too! ;) Sounds like you have a hoarding problem! :tree: Welcome to our world! :loco: :crazy: :rofl: :lol:
