Newbie From NY
Discussion in 'The Wood Pile' started by NewYorkNewJack, Nov 11, 2023.
  1. NewYorkNewJack
    NewYorkNewJack
    10547 - Mohegan Lake NY
    I’ll get a MM this week and resplit it and see what the MM reads Chilidawg
  2. metalcuttr
    metalcuttr
    western WA
    Hey NewYorkNewJack , Glad to meet you! Lots of very knowledgeable folks here. Sounds like you are into some good firewoods. We burn mostly Fir and Medrone here in the Pacific NW. By all means take Backwoods Savage 's advice and add some goodies to your signature line. It is fun and interesting to all! We also love pictures. Again, a hearty welcome!:handshake:
  3. NewYorkNewJack
    NewYorkNewJack
    Thanks metalcuttr . I’ll take all the advice from here. I put some stuff into the signature
  4. Erik B
    Erik B
    Western Wisconsin
    Welcome to the forum NewYorkNewJack :handshake: There is a lot of good info shared here. However, we do like a bit of fun picking on each other. All in jest, tho.
  5. NewYorkNewJack
    NewYorkNewJack
    That’s fine with me. Life is too short to take things serious Erik B
  6. The Wood Wolverine
    How much wood do you burn per season NewJack?
    I’m in the 4-5 cord range. Currently have about 22-23 cords c/s/s. :salute: One of the first things I learned on this forum was the 3 year plan. Then I surpassed 3 and went to 4, then 5. :cool:
  7. NewYorkNewJack
    NewYorkNewJack
    I usually burn about 4 for the last few years due to a mild winter. I don’t like to pay the oil man anything. I get about 1 fill up a year so that makes me happy. I’m trying to get into a 3 year plan and I think I’ll be able to do that with this tree guy that I recently became friends with.
  8. Locust Post
  9. NewYorkNewJack
    NewYorkNewJack
    Thanks , I’m happy to be here even though it’s been only a day but sure can see the love every one here has for each other. Now I know I look forward to talking to you all Locust Post
  10. Scotty Overkill
  11. Marshy
    Marshy
    CNY
    Some people claim Ash will dry in the amount of time it takes to hit the ground from standing. The old tale is it can be burnt green. Something about the species just seems to dry a lot faster than others. I split mine in Nov/Dec and burn it the following year. I've split and stacked it as late as early May and it's dry enough that same fall/winter. It might have more to do with how and where it's stacked but you can get it down under 18% in about 9 months.
  12. Cash Larue
    Cash Larue
    Pine, CO
    Hi NewYorkNewJack
    Welcome aboard! I was thinking about your splitter. I have a similar 28 ton splitter with a 9.5 horse Koehler motor. I’ve noticed that if I draw the cylinder back all the way before I shut it off, it can make startup very difficult the next time I use it. It puts pressure on the motor. So I’ve learned never to draw the cylinder back all the way. I always give the cylinder a half inch or so of wiggle room before I shut it down.
    Hopefully it’s that simple. Worth a look, anyway!
    Good luck!
    -Cash
  13. NewYorkNewJack
    NewYorkNewJack
    Thanks so much for the tips Cash Larue ill try that
    Cash Larue and metalcuttr like this.
  14. Geoff C
    Geoff C
    NEPA
    According to the firewood poem ash is tops
    Beechwood fires are bright and clear
    If the logs are kept a year,
    Chestnut's only good they say,
    If for logs 'tis laid away.
    Make a fire of Elder tree,
    Death within your house will be;
    But ash new or ash old,
    Is fit for a queen with crown of gold
    Birch and fir logs burn too fast
    Blaze up bright and do not last,
    it is by the Irish said
    Hawthorn bakes the sweetest bread.
    Elm wood burns like churchyard mould,
    E'en the very flames are cold
    But ash green or ash brown
    Is fit for a queen with golden crown
    Poplar gives a bitter smoke,
    Fills your eyes and makes you choke,
    Apple wood will scent your room
    Pear wood smells like flowers in bloom
    Oaken logs, if dry and old
    keep away the winter's cold
    But ash wet or ash dry
    a king shall warm his slippers by
  15. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    That’s kind of an understatement
  16. brenndatomu
    Yeah, I kinda suspect the physiological response is a lil stronger than that...:whistle:
