New Woodstock IS, first cure and burns complete!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Wade, Feb 1, 2019.
  1. Matt Fine
    Matt Fine
    New York
    Love the theme!
    The outside air is going to be more efficient. If you burn warm inside air, it needs to be replaced with cold outside air. If you burn outside air, your well sealed house will have less air turnover.
    I will also add to the flue damper suggestion. I added one after the first year with the IS and it only cost about $10 and only took about 20 minutes to install. Most of the time was because I had to cut a pipe to make room. If you have adjustable pipe, you could install one in a couple minutes.
    The flue damper has made a huge difference in my ability to stuff the stove to the gills and yet still keep the initial peak tamed and the full burn extended and more even.
    Slocum, Maina, Mitch Newton and 3 others like this.
  2. BranBranTheNWman
    BranBranTheNWman
    Maple Falls, Washington
    Beautiful stove and install. If I were to do it again I would get a IS, such craftsmanship. But I do love my plain Jane Recency F2400
  3. Wade
    Wade
    Missouri
    No one right now, we futureproofed our home, we have a ramp into the house from garage too, all ada doors in home, and we have three closets that are framed for an internal elevator from basement to second floor. All with seperate removeable floor joists that are framed for removal. Ramps made moving in a breeze.
    Chvymn99, Chaz, Matt Fine and 2 others like this.
  4. Wade
    Wade
    Missouri
    Thanks for that suggestion. I will look into it.
    Chvymn99, Slocum, Chaz and 2 others like this.
  5. DNH
    DNH
    Missouri
    What part, I’m near Springfield and am well acquainted with our rocks!
  6. Wade
    Wade
    Missouri
    Other side of state, South of Fredericktown,
    Chvymn99, Slocum, Chaz and 1 other person like this.
  7. DNH
    DNH
    Missouri
    Nice area a little tougher and even more rocky than here!
  8. amateur cutter
    That is a beautiful setup Wade. Love the planning on the whole project! Glad to have you aboard as well. I predict that your heat pump gets very little use in the future. Great stove & plenty of seasoned wood, what's not to love!
    Chvymn99, Slocum, Chaz and 3 others like this.
  9. Chaz
    Chaz
    Southwestern NY
    Excellent foresight in the planning stages.
    :yes:
    Hope no-one ever needs the ramps, nor the elevator, but you definitely went long term with your plans.
    Great thinking.
    :sherlock:
    Maina, Chvymn99 and Slocum like this.
  10. Canadian border VT
    Welcome to the FHC Wade .. first of all congratulations on a great stove and building a forever home! Most people do not.
    Maina, Chvymn99, Wade and 2 others like this.
  11. BigPapi
    BigPapi
    The hills of Western MA
    That's a great looking stove and setup, Wade! You and Mrs Wade should be proud! Thanks for joining up and sharing your pics and stories.
  12. Wade
    Wade
    Missouri
    Thanks, we are happy, waited a long long time to get what we wanted. Glad to be aboard.
