New Woodstock Blog info Ideal Steel
Discussion in 'Modern EPA Stoves and Fireplaces' started by Oldhippie, Mar 3, 2014.
  1. BrianK
    BrianK
    West central PA
    That's a good change. I tried to tighten the latch to make the door seal tighter and sheered off one of the bolts holding the latch to the body of the stove when I tried to loosen it. It turns out it wasn't even necessary. The Allen head bolt holding the handle to the door had worked its way loose making it seal poorly. All I had needed to do was tighten the Allen head bolt. The new door handle fixes that too.
    They listen very closely to their Beta testers' reports. :thumbs:
  2. Flamestead
    Flamestead
    Windsor County, VT
    Two slabs standing on end on the sides (so 9" wide), and three across the back (7+").
    I like the latch looks. Screwing the top side-pieces on is a good idea, but after you drop them off once or twice by accident you start to get the clue. We are quite interested in the door gasket moving inward. I think it should help reduce the ash that can fall between the frame and door (and the onto the ash lip when you open the door).
  3. weatherguy
    weatherguy
    central massachusetts
    You'll be fine if you use a fire damper, they cost under $100 and pass code and insurance companies are ok with them.
    Backwoods Savage and Oldhippie like this.
  4. ZeeB
    ZeeB
    HA , been there, done that, at least twice!
    Flamestead likes this.
  5. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I keep going back and forth on what to do. Like the looks of the IS and the increase in firebox whould be nice as well.
