New wood stove advice sought
Discussion in 'Modern EPA Stoves and Fireplaces' started by BZOR, Dec 14, 2017.
  1. concretegrazer
    concretegrazer
    Southwest MO
    Did you look at a neostone 2.5 BZOR ? Same size/firebox as the Newcastle .
    BZOR likes this.
  2. BZOR
    BZOR
    Oregon
    Yes we're considering it as well, unfortunately it doesn't provide the looks my wife is looking for. If it wasn't for my wife wanting a white stove, that would probably be the stove I would buy.
    concretegrazer likes this.
  3. Ronaldo
    Ronaldo
    It is our primary heat source, I run the furnace fan on occasion during extremely cold temps to even out the heat. Only run my furnace a little in spring and fall just to keep it in working condition. Well insulated house built in 1998 and located in central Iowa. The only issue when its super cold and I'm running it hard is some coal build up. Whole family like the stove and it's easy to operate. Easy stove to start a fire in too, it really takes off burning well.
    Sent from my SM-S320VL using Tapatalk
    BZOR, TurboDiesel and concretegrazer like this.
  4. concretegrazer
    concretegrazer
    Southwest MO
    If white is the big catch your looking at asummit in ivory, the aforementioned t5 or the quadrafire explorer 2 or 3. Surprised jotul doesn't offer a white enamel anymore.
    BZOR likes this.
  5. mike bayerl
    mike bayerl
    BTW, if you do go with a PE stove, I would recommend getting the blower with it. It is pretty expensive, but it does help alot.
    BZOR and OhioStihl like this.
  6. dingbat
    dingbat
    Western Northern Cackalaky
    When sizing a new stove, is there any point that it can be too big?
    papadave and TurboDiesel like this.
  7. TurboDiesel
    Yes.
    Especially if it's in the room where you spend most of your time
    papadave and dingbat like this.
  8. dingbat
    dingbat
    Are you talking about it getting uncomfortably hot? Can't just do smaller fires?
    Reason I'm asking is a buddy at work is building his house right now. 1500 sqft, 1000 sqft attic that may become a bonus room in the future. He's looking at a Jotul F600. 80,000 some aught btu, heats up to 2,600 sqft. Think that's too much stove for a living room with semi open floor plan?
    TurboDiesel likes this.
  9. Ronaldo
    Ronaldo
    Sounds like that model would be appropriate.......location and environment play a part.
    dingbat likes this.
  10. TurboDiesel
    With an open floor plan it should work fine. It's hard to get heat flowing to the separate rooms. Would probably work the best if the stove was close to the center of the house
    dingbat and Ronaldo like this.
