New welder thoughts
Discussion in 'The DIY Room' started by Camber, Dec 15, 2018.
  1. WeldrDave
    I used one of their Inverters years back. Was a good machine but you needed a strong power source to it! It would fluctuate if it wasn't on 3 phase.
    Screwloose and Pallet Pete like this.
  2. Pallet Pete
    Pallet Pete Moderator
    Ovid
    If your financing here is the Lincoln Generator multiprocess welder as well. I have no experience with this model although we use a few Lincoln units in or collection at work and they are very nice machines too.
    Rated 225 Amps/25 Volts/40% duty-cycle and 210 Amps/25 Volts/100% duty-cycle for CC. All rated outputs at 104°F (40°C)
    Lincoln Electric Eagle 10,000 Plus Multi-Process Welder/Generator with 674CC Kohler Gas Engine and Electric Start — 50–225 Amp DC Output, 9,000 Watt AC Power, Model# K2343-3 | Northern Tool + Equipment
    Camber, Screwloose and WeldrDave like this.
  3. WeldrDave
    Nothing wrong with a Lincoln!!! My "only" beef with them is they always seemed a little more in $$$ than most other machines, "Exellent quality" though... :yes:
    Pallet Pete, Screwloose and Camber like this.
  4. WeldrDave
  5. Camber
    Camber
    Montana
    We have a place that sells hobart called Murdochs. I called and they wanted me to call back Monday. The salesperson doesn't work Sunday. I think Pete is right on having two welders. That champion elite is looking pretty good. I want to se if they have a better price other than the MSRP listed on hobarts website.
    Screwloose, Pallet Pete and WeldrDave like this.
  6. Camber
    Camber
    Montana
    That is precisely what I don't need Dave. My first bandsaw was a cheap import. Motor burned up in two days of moderate cutting.
  7. Camber
    Camber
    Montana
    That is a good option too. Nortern also has a comparable hobart model for 600 less. Would you say the Lincoln is still the way to go? I see the hobart doesn't have leads with that price.
    Screwloose likes this.
  8. Camber
    Camber
    Montana
    Shopping Cart | Northern Tool + Equipment
    I hate shopping. Ok, if this pulls up correctly...this is what I've distilled my options to.
    For a couple hundred bucks less I can get the hobart with 5 foot leads. What say you guys? I will leave it lay after this. Thanks for taking the time, and not letting me get too cheap.
  9. WeldrDave
    Nothing came up... :confused::whistle:
  10. chris
    chris
    SE WI
    5 foot is too short, you be forever fighting with the unit getting in the way. or never quite enough to reach some odd place/posistion. Like a power cord it's always just a bit short. Current welders in shop Miller Dial arc 250 HF, Old Lincoln Torpedo ( the old geter done no matter what unit) and a 90amp lunch box mig unit that Lincoln owns- forget name similer to hobart /miller deal. The big miller and that torpedo are real mean on the electric meter, so starting to shop around for a all in one unit including ac tig . Also have a Ready Welder spool gun. Kinda touchy on the feed control easy to bump out of setting.
    Screwloose, Camber and WeldrDave like this.
  11. WeldrDave
    I would say, go with your gut! Leads are "NOT" cheap to buy, just remember that. The Lincoln Pete showed had 20ft of leads come with it. If you get a Hobart "with" leads, thats the way to go, "my opinion"... 5 year Warranty also.
    Screwloose, Camber and Pallet Pete like this.
  12. WeldrDave
    Yes it is!!! That almost doesn't sound right. 15' maybe... ? I have 2 sets of 25ft and even they seem short at times. I normally use my 50ft'rs
  13. Camber
    Camber
    Montana
    Yes sir. The hobart price was with 50 foot leads. Still cheaper than the Lincoln. I'm going to trade 8 hours of labour for a map 211 I believe it is. That will be in the spring sometime. The hobart is realky looking sex right now.
    Pallet Pete, Screwloose and WeldrDave like this.
  14. WeldrDave
    They always are for what ever reason!!! You can't go wrong with the Hobart! :yes:
  15. Camber
    Camber
    Montana
    WeldrDave and Screwloose like this.
  16. JustWood
    JustWood Guest
  17. Screwloose
    Screwloose
    The motor generators, are super smooth. I cut my teeth on a 20hp Hobart. I have a heavy as @&#t one made by P&H Harnischfeger. At my first job I was pulling the Hobart through the plant and turned to fast and it fell over. Took 2 forklifts to get it up. Thankfully it fell on the back, if it would have fallen on the dial side...... the guys plastered it with "this side up stickers" I never lived it down.
    Camber likes this.
  18. chris
    chris
    SE WI
    like my Miller dial arc 250 hc around 700 # mine is just a plug in though.
  19. Screwloose
    Screwloose
    Camber and SKEETER McCLUSKEY like this.
  20. Screwloose
    Screwloose
    Man I jinxed myself. Yesterday I say my only repairs been brushes and today the pump on the Miller cooler starts leaking.....
    WeldrDave and Camber like this.
