new toy
Discussion in 'Chainsaws and Power Equipment' started by Woodsnwoods, Nov 5, 2015.
  1. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I generally think this is a good tractor for the money. It does not have a huge loader capacity, but for around the house it works great. Much like chainsaws, always want the next size bigger
    mike bayerl likes this.
  2. 94BULLITT
    94BULLITT
    Frederick County, VA
    You need a 3rd function.(It give you 2 buttons on the loader joystick to open and close it) W R long makes one and it gets good reviews on the tractor forums.
  3. fuelrod
    fuelrod
    Western Maine
    Hey Woods, JD sells the hook & bullet (JD's quick connect) set up for about $40 to fit your machine. That should make your mod's a bit easier from the SS hook up. OR if you found a dealer (for the grapple), he might have the correct set and swap with you. One suggestion, a friend has the same grapple and those mounts are prone to twist. I would add a little continuous steel from left to right to "tie" both sides together, or a few diag. braces from the outer sides of the mount to the main body of the grapple on each side.
    Woodsnwoods and concretegrazer like this.
  4. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Thanks for the info, will look into this very soon.
    94BULLITT likes this.
  5. concretegrazer
    concretegrazer
    Southwest MO
    Is this it?
    Valve Kits
  6. Gasifier
    How much does that grapple weigh woods?
  7. 94BULLITT
    94BULLITT
    Yes, that is it.
  8. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    A little over 300 lbs according to the manufacturer. That is why I opted to hack and weld to mount it vs adding another 100lbs with the adapter. Not going to be I king huge loads, but picking from the landscape trailer and holding logs while cutting is the plan...
