New to me issue - bogs in cut, but doesn't die...
Discussion in 'Chainsaws and Power Equipment' started by NewToStihl, Oct 6, 2014.
  1. NewToStihl
    NewToStihl
    Central Indiana
    Thanks for all the feedback fellas. Here's what I can tell you...
    • Chain is sharp and rakers are set to standard gage height
    • Drive links are good - at least good enough that the chain will spin freely in the bar when advanced by hand to set chain tension.
    • The filter is very clean, but I will definitely try a cut without it when I get a little more shop time later this week.
    • A known good 441 carb won't be easy to come by for testing purposes...
    • Tank vent is functioning correctly
    • Saw passes press/vac testing
    I'm hoping to get back out to look at the saw Thursday evening, so I'll report back with what I find.
  2. clemsonfor
    Too much oil on clutch?
    Bit you swapped clutches and still had problem? Or did you just swap drums? I have to go reread.
  3. Jon1270
    Jon1270
    Pittsburgh, PA
    Ah, I see. Low power causes the RPM's to drop, so the clutch doesn't hold as firmly and can slip.
    MasterMech likes this.
  4. the GOAT
    the GOAT Banned
    Maine
    Collapsing impulse or fuel line?
  5. mdavlee
    mdavlee
    Fuel or coil. Check the spark plug and replace just for the heck of it.
  6. foragefarmer
    foragefarmer
    Central, Virginia
    I had a collapsing fuel line on a 028 one time. Line was basically goo in the tank.
    mdavlee likes this.
  7. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    I just had the same problem, fuel line collapsed just outside the tank exit it would run and rev but no power under load.
    mdavlee likes this.
  8. prell 73
    prell 73
    ia
    Needs more high side rpm'
    DexterDay likes this.
  9. SquareFile
    SquareFile
    somewhere
    Holy crap prell your bumping everything;):rofl: :lol:
  10. prell 73
    prell 73
    ia
    Sorry this site is awsome!
    thistle, splitoak, basod and 4 others like this.
  11. clemsonfor
    I just said that to one of his other posts , haha!
  12. SquareFile
    SquareFile
    somewhere
    He is excited and it can be a fun place to hang
    splitoak, DexterDay and clemsonfor like this.
  13. NewToStihl
    NewToStihl
    Central Indiana
    I apologize fellas - I should have followed back up with this thread and never did. Nothing worse than a thread just hanging out there in the breeze!
    I had thoroughly cleaned the carb on this saw and that made no difference. I didn't put a carb kit in, but did completely disassemble it and gave it a few rides through the US cleaner. This provided no improvement. I was eventually able to come up with another carb to try on the saw and it ran fine after that. So, I know the carb was the problem, but what exactly about the carb was causing the issue I unfortunately do not know...
    Certified106 likes this.
  14. FredRed
    FredRed
    NW Connecticut
    Sometimes all the cleaning in the world won't clean up all of the contaminates in the carb unless you remove the welch plugs. Glad you got it sorted out.
  15. chris
    chris
    SE WI
    ethanol fuel - so much fun to work with. leaves deposits or causes oxidation of the tiniest passages in a carb , barely detectable in some cases.
  16. prell 73
    prell 73
    ia
    That's why I run only stihl motomix.
  17. NewToStihl
    NewToStihl
    Central Indiana
    That's not a bad idea, but gets very pricey if you go through much fuel at all. I use ethanol-free gasoline in my mix and drain fuel lines when a saw is going to sit for a longer period of time. The saw I was having the carb problems with was a new acquisition...
  18. clemsonfor
    Yea I run ethanol free fuel.
    No way I am running canned fuel :eek:. Thats quite a bit of money. I can buy a carb every couple of years with the savings of running E free fuel.
    My 650 uses a whole quart of fuel per tank. One day this summer I burned a gallon of fuel cutting firewood.
    What does that stuff cost like $15/qt?
  19. prell 73
    prell 73
    ia
    Try 1 can it will clean the carb yes pricey but worth every penny
  20. prell 73
    prell 73
    ia
    8.00$ a can
