New Stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by TBONE, Dec 1, 2016.
  1. TBONE
    TBONE
    Carey, Ohio
    :p
    Eric VW, Thor, milleo and 3 others like this.
  2. Canadian border VT
    T-BONE I am real interested in this also.. maybe some test results and pics for real life burns!
    Eric VW, Thor, Todd 2 and 2 others like this.
  3. Todd 2
    Todd 2
    My low and slow is when temps out side hang around that 35 to 50 deg. area. I always heat the chimney pipe up good on a cold start or reload and haven't had a stall yet. When its colder out adjust stat and load size as needed. Don't be afraid to stuff it full she will cruse right along at 275 or 700 deg stove top tempature all controlled by the turn of the dial. :) A stove top thermometer and pipe probe are handy to help get a feel for things.
    papadave, Chvymn99, Eric VW and 7 others like this.
  4. TBONE
    TBONE
    Carey, Ohio
    Thanks Todd! I'm planning on ordering the fluegard pipe temp and I'll be sure to add the inferno stove top thermometer to the order. I've only had 2 cold starts in the stove and since the 2nd one she has been running non stop one way or another since. Once I get my double walled pipe installed I'll definitely turn it up. I'm going to be changing my wood split size to the medium/large size from now on which will help on the long slow burns. Currently it's of the small/medium size and I've got about 7.5 cords of this to go through.
  5. raybonz
    raybonz Moderator
    Carver, Mass.
    Nice looking stove and install! This is a look I could get used to! Congrats and good luck!
    Sean, papadave, Eric VW and 3 others like this.
  6. Melanie
    Melanie
    Indiana
    Double wall is what I have, corner installed PE in a cabin. I can't imagine how hot a single wall pipe gets. The dbl can heat up, but the walls are not affected.
  7. Melanie
    Melanie
    Indiana
    That's a very pretty wood stove.
    Sean, papadave, Eric VW and 4 others like this.
  8. Babaganoosh
    Babaganoosh
    Jersey Shore
    Very nice stove. People talk about using less wood with a cat stove but I find that you use just as much as the regular epa stoves because you can start burning earlier as well as stop burning later in the season. I also found out how important dry wood is with a cat stove. They really thrive on it.
  9. TBONE
    TBONE
    Carey, Ohio
    Thanks Raymond! I'd say by the looks of that wood stove in your avatar you already are used to it with the physical similarities between the two.
    Thanks Melanie! It's a beautiful stove and I'm enjoying it more and more each day.
    Thanks Babaganoosh! Yes, I can already tell what a big difference a cat stove makes in the amount of wood used. I'd agree with you on the usage amount of wood with the earlier and longer burn seasons. It's probably close to the same.
  10. Locust Post
    Very good looking stove TBONE ...enjoy....I love my cat stove.
  11. CNE deer
    CNE deer
    ohio
    Looks good TBONE now we need some cold weather to get that baby cranking!
  12. Horkn
    Yeah, they actually have that. I thought the"green start" thing was kind of crazy.
  13. Kimberly
    Kimberly
    The Kangaroo State
    Don't forget if you change to double wall pipe you will need a probe thermometer.
    papadave likes this.
  14. papadave
    Good catch!
  15. TBONE
    TBONE
    Carey, Ohio
    Yep, already ordered it the other day. Pipe got installed this afternoon.
    Thanks Locust and CNE!
  16. eatonpcat
    Beautiful room and stove, stay warm!
    will711 and papadave like this.
  17. will711
    will711
    Pocono Mts.
    X2 on that hearth looks fantastic :thumbs::cheers:
  18. papadave
    Same here.
