New Saw Problem
Discussion in 'Chainsaws and Power Equipment' started by campinspecter, May 10, 2018.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    Do you have another chain you could try on it?
  2. Chaz
    Chaz
    Southwestern NY
    Well campinspecter at least your still cutting straight. :)
    Last year I sharpened mine, and it scalloped the cuts.
    Like a big huge U on the cut. Needless to say, I took that chain off and put on a fresh one.:whistle:
  3. huskihl
    huskihl
    Weird that the cuts are straight, just on an angle. May need to adjust the sights :D
    MikeInMa, Moparmyway, M2theB and 8 others like this.
  4. Chaz
    Chaz
    Southwestern NY
    OK, this is likely a stupid thought, I've had more than "2" over the years.;)
    Could it be that the weight difference between this saw and your old saw is such that it is cutting downward at an angle, and you aren't compensating for the weight difference??
    The cuts are straight, but angled. Given a new saw with different weight, and possibly not the same "balance" of the other saw, could be for lack of compensation on the part of the new saw.
    I'm a novice when it comes to sharpening and cutting, so it's not something I've experienced before.
  5. huskihl
    huskihl
    Very possible.
  6. Backwoods Savage
    I can see a slight curve in the cut but not really that bad. It could very well be the difference in the size of the saw throwing you off but I'm not totally convinced on that. Hope you find out and let us know.
    Shawn Curry, campinspecter and Chaz like this.
  7. campinspecter
    campinspecter
    Bought a new chain and bar for the 570 two weeks ago. Both the 570 and 390 are doing the same thing. I think it's a batch of bad chain.
    leoht, brenndatomu, Horkn and 4 others like this.
  8. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    I would pull the b/c and see if the is a slight bend in the bar. Just because it's new does not mean it is strait. Could have got a tweek somewhere. Also check to see if it is mounting true to the case. If not the bar I would say chain.
  9. 94BULLITT
    94BULLITT
    touch up the chain and see how it does
    Shawn Curry and Backwoods Savage like this.
  10. fuelrod
    fuelrod
    Western Maine
    That is a "stumper" Allan!
    Do you normally run a skip tooth chain? I'm really "swinging wide" (wag)* with this one, but with a skip tooth with half the teeth, a bastard length bar you might have an extra left cutter that would be a bigger issue over a regular tooth chain.
    *wag = wild aaz guess, I learned that here at WHC!:D
  11. campinspecter
    campinspecter
    The Dealer went right to work on the bar and chain. He put on a new wide gauge bar and told me to run the saw wide out and dig the dogs in and make it cut. It works much better now. The dealer did this at no cost to me.
    The log that I bucked was a yellow cedar - three foot in diameter. I cannot believe the speed in which the new 390 went through the log compared to the old 570.
    ChipsFlyin, basod, tamarack and 13 others like this.
  12. jon1212
    jon1212
    Utah........ugh!
    Huh? What does that mean?
    Horkn and campinspecter like this.
  13. campinspecter
    campinspecter
    It means operator error in that I was not wanting to push the new saw too hard as per instructions in the manual. I let the weight of the saw take the bar through the cut. The weight of the saw being heavier on the side opposite the bar slightly made the bar side higher making the cut go to the right.
    I think going to the dealer and eating some humble pie is in order!
    basod, Hammy, M2theB and 8 others like this.
  14. campinspecter
    campinspecter
    I owned 076 Stihl and ran a forty two inch bar on it and just let the weight of the saw supply the force to make the cut. No issue of the cut running sideways.
    basod, Andyshine77, Chaz and 3 others like this.
  15. campinspecter
    campinspecter
    I think it means the rails are thicker, making the groove narrower.
    Horkn and Chvymn99 like this.
  16. Shawn Curry
    Shawn Curry
    Western NY
    I’ve also seen that before - the cutters were sharp but the angle was a little bit different from side to side.
    But if he changed to a different bar that could well have been the problem too. Glad you got it sorted out! Touch up the chain if it still feels wrong to you.
    Andyshine77, leoht, Chaz and 3 others like this.
  17. campinspecter
    campinspecter
    You were right on!
    basod, wildwest, huskihl and 4 others like this.
  18. campinspecter
    campinspecter
    Its really feels good to have things sorted out!
  19. campinspecter
    campinspecter
    Now things are sorted out, I have to go back to the dealer and straighten things out as I now have a extra bar and chain which cost me nothing. The new bar and chain, although it's a thirty six inch bar and chain, is a inch and quarter shorter than the original bar. When I bought the saw, I got four chains with it. The dealer has a deal - if you buy three chains, you get the fourth one free, so now four chains have to be shortened to fit the new bar. What would be a fair way to to straighten things with the Dealer, money wise?
    wildwest, Chaz, Hammy and 1 other person like this.
  20. Shawn Curry
    Shawn Curry
    Western NY
    If he sold you a mismatched bar and chains in the first place, I’d hope you could just return the wrong ones and he’d make it right. Especially if you just spend a grand or two in there the other day.
    He gets his lightly used bar and bad batch of chains back, and you get 3 new chains that are the right ones for your new bar. Seems only fair to me.
