New rig
Discussion in 'Everything Else (off topic)' started by Ron T, Nov 30, 2022.
  1. Locust Post
    Best there is in my opinion but I would suggest just going to each products web pages and read up. One main difference is that Corrosion X is supposed to stop rust that may have started which I believe in my experience it does so not just a preventative. The aviation version is used where there is a lot of liquid ice melters used to protect aircrafts and the HD is used by marine industry where there is a lot of salt water exposure. But as I said read up on the product pages.
  2. The Wood Wolverine
    I use FF on my truck and I’ve had WoolWax spayed on the Jeep. I think they both work as advertised. I’m wanting to get a spray gun soon. Definitely will check it out.
  3. In the Pines
    In the Pines
    I've never used wool wax but it seems to be the same as fluid film from what I read several years back.
    Corrosion x seems to hold up better than fluid film.I personally have never did a side by side comparison, I use fluid film at work though.
    Corrosion x gives a better film shell than fluid film I think. It has a "harder" sheen to it than fluid film or a waxier look. just my observation. Both will smear if you brush up against the treatment.
    I liked the corrosion x because it supposedly is suppose to stop corrosion, while fluid film just coats.
    Project farm did a comparison of these so you can see his results.
    Crc did the best in his video though.
    I see locust Post also said the same about rust prevention/stopping. didn't read thru all the responses..
