New Moisture Meter Not Working
Discussion in 'Everything Else (off topic)' started by firecracker_77, Dec 26, 2013.
  1. firecracker_77
    firecracker_77
    IL
    Got a meter for X-Mas. Popped the prongs into wood and nothing. I need to play with it some more before I deem it a dud. Was disappointed. There's only a couple buttons...how hard could this be?
  2. Grizzly Adam
    Grizzly Adam Guest
    Check the battery compartment for one of those pieces of plastic that keeps the batteries from running dead on the shelf.
  3. firecracker_77
    firecracker_77
    IL
    The batteries are working and it's powered up. I'm just not getting any reading.
  4. MasterMech
    Not even across your palm?
  5. chris
    chris
    SE WI
    wood being checked needs to be in the same temp range as what painting would be. Possibility that battery is weak. Use alkaline. Referance the manual is there a calibration adjustment? You should get about 25-30% across your palm.
  6. firecracker_77
    firecracker_77
    IL
    got a reading across my palm...that's good
  7. Grizzly Adam
    Grizzly Adam Guest
    Sounds like your wood is defective. Throw it out and get new.
  8. firecracker_77
    firecracker_77
    IL
    LOL! How far do you jab this meter into the wood?
  9. Grizzly Adam
    Grizzly Adam Guest
    Give it a good hard jab!
  10. MasterMech
    I try to sink the pins in at least a 1/4". A good strong push, maybe some wiggling, ought to get her done. :zip:
  11. firecracker_77
    firecracker_77
    IL
    I was worried about damaging the meter. Ok...sounds good
    clemsonfor likes this.
  12. chris
    chris
    SE WI
    Make sure when you check the wood that you do so on a fresh spilt open face. In other words take a split replit it and check in middle, pins with the grain.
    firecracker_77 likes this.
  13. firecracker_77
    firecracker_77
    IL
    What does pins with the grain mean? The meter parallel with the wood or perpendicular to the grains?
  14. fox9988
    fox9988
    NW Arkansas 72717
    Parallel
    I've tested both ways and not seen much difference on the same piece of wood, but parallel is the correct way.
    will711 likes this.
  15. will711
    will711
    Pocono Mts.
    Parallel
  16. will711
    will711
    Pocono Mts.
    Beat me too it:)
    fox9988 likes this.
  17. fox9988
    fox9988
    NW Arkansas 72717
    I type at the speed of smell:D
    will711 likes this.
  18. firecracker_77
    firecracker_77
    IL
    Ok guys. I think I wasn't pushing hard enough. Was at someone's house when I opened the present, and they've had that same firewood sitting next to their fireplace for a couple years, so I was surely going to get an awesome reading, but I may not have pushed the pins in enough out of fear of breaking it. My palm reading was over 25%
  19. chris
    chris
    SE WI
    Yep bout right for palm
  20. Grizzly Adam
    Grizzly Adam Guest
    Sounds a little dry, better start hydrating.
    firecracker_77 and eatonpcat like this.
