New Mill
Discussion in 'The Sawyer Room' started by lukem, Feb 8, 2021.
  1. JB Sawman
    JB Sawman
    pennsylvania
    I usually run washer fluid and pine sol mix this seems to work real well for me but I cut mostly hardwoods it was also recommended to use cotton picker spindle lube it is also water based and works well cutting sappy wood like pine ,cedar etc I use the washer fluid mix all year but especially when freezing might be a issue in my books it is always recommended to use a new blade when making adjustments glad you are getting it together JB
    stuckinthemuck and fuelrod like this.
  2. lukem
    Going to try to mill some walnut this evening.
    JB Sawman and Need2Saw like this.
  3. JB Sawman
    JB Sawman
    pennsylvania
    :popcorn:
  4. lukem
    Still getting set up but made a few cuts. Need to adjust my guides to keep the blade from climbing in the cut, especially on figured grain.
    Got 2 logs done...and one big one set on the mill for tomorrow.
  5. Ward Hoarder
    Ward Hoarder
    West Virginia
    Good luck setting up the mill.
    Looks like a nice setup you have there.
    Always liked the IH/CASE 2 wheel drive tractors. Spent many hours on them.
  6. lukem
    It's barrowed, but it is nice.
  7. fuelrod
    fuelrod
    Western Maine
    Pretty cool eh?:thumbs:
  8. fuelrod
    fuelrod
    Western Maine
    I'm still playing with my alignment. The factory said that I needed to adjust so that spinning it in BOTH directions 20+ wheel revolutions it doesn't walk :hair:. It seems that I can get it good, release the blade tension and come back to it the next day and it's "walking" .
    :picard:
    I guess all along I was cutting nice and straight-flat but up against the flange on the guide wheels, that they say is not right and will prematurely wear both the blades and guide wheels.
  9. lukem
  10. lukem
    I fine tuned mine with the blade running at idle. A little adjustment goes a long way.
    Stlshrk and fuelrod like this.
  11. fuelrod
    fuelrod
    Western Maine
    I have my fingers crossed after getting both big wheels in agreement 25 revs in each direction, previously I wasn't messing with the vertical (plumb) axis, that adds a bunch of new possibilities for screwing up. :rofl: :lol:
    Dialed in the guide wheels on both axis and down pressure also.
    I'll see tomorrow.
    That B/W is beautiful :yes:
