new member needs some help...
Discussion in 'The Pellet Bag' started by Scotty Overkill, Jan 5, 2015.
  1. imacman
    imacman
    Denver, NC
    Welcome to the forum Jerseygirl!
  2. Gasifier
    Ya. You pellet heads are so cute too!:D:rofl: :lol:
  3. imacman
    imacman
    Denver, NC
    jerseygirl Just curious, does your stove have an OAK?
    savemoney, DexterDay and will711 like this.
  4. jerseygirl
    jerseygirl
    New Jersey
    What's an Oak?
  5. IHATEPROPANE
    IHATEPROPANE
    Outside
    Air
    Kit
  6. imacman
    imacman
    Denver, NC
    As IHP said above, an Outside Air Kit.....it's connected to your air inlet on the stove and uses outside instead of indoor air.....helps reduce drafts, and doesn't send already heated (and paid for) warm air out the exhaust.
    savemoney likes this.
  7. savemoney
    Thank you for addressing that! I'm exhausted from bringing it up so often and then having to defend it. Just went through the this with my daughter's boyfriend. He looked into it and has assembled the material to put in his OAK.
    imacman likes this.
  8. Lousyweather
    Lousyweather
    BUT, heres the thing about the above link.......its for the Accentra Insert, and I was under the impression JG had a 52I, which is a totally different animal altogether! No more long tubes to clog, etc......I don't believe there are cleaning instructions online for it yet, other than the manual.........
    jerseygirl, IHATEPROPANE and will711 like this.
  9. will711
    will711
    Pocono Mts.
    LW it's so nice that you are here :thumbs: a trained and certified expert to help keep us on the right path . Thank you :handshake: J girl I hope I didn't give you some bad advice :(
    Lousyweather and IHATEPROPANE like this.
  10. Lousyweather
    Lousyweather
    there's no bad advice, Will! Your post will help those tens of thousands of folks who actually do own a Accentra Insert......they stopped making these in 2013 though....I think July or so. Everyone after that date has a 52i, unless it came from "old" stock.
    I just mention it because the firebox, and therefore, cleaning, of the "new" 52i is quite different than the "old" Accentra Insert, but there are also similarities as well.
    I only hope JG does have the 52i and I didn't totally screw her up by mentioning the other insert!
    AS for "trained and certified EXPERT"....well, Im waiting for the other shoe to drop on THAT one! :jaw:
    will711 and slvrblkk like this.
  11. Birddog91
    Birddog91
    Lakes Region NH/Connecticut
    OK My stove is free standing and goes out my chimney, would I still be able to use the "OAK"?
    wildwest, will711, eatonpcat and 2 others like this.
  12. smoke show
    smoke show
    Pittsfield, Wi
    Anythings possible man you own a liquor store!
    will711, eatonpcat, subsailor and 3 others like this.
  13. eatonpcat
    My thoughts exactly!!
    will711 and smoke show like this.
  14. jerseygirl
    jerseygirl
    New Jersey
    No worries, I am still just vacumming the front , I was told by the installer that a more detaed cleaning won't be necessary until the end of the season.
    will711 and wildwest like this.
  15. eatonpcat
  16. subsailor
    subsailor
    Winthrop, Maine
    I think you'll get a lot of arguments about that from the people on this site. I and most others clean our stoves to varying degrees weekly.
    wildwest likes this.
  17. Lousyweather
    Lousyweather
    heck, Ill bite......
    Just vacuuming the front out, and not removing the exchanger covers, etc, will result in you getting less and less heat from your unit as winter progresses. Now, us pellet guys love you to burn more pellets, but don't you really want to get the most bang for your buck with your stove and pellets? Most here do.......
    because I am a helpful guy, here is a link to your 52i Owners' Manual..... http://hearthnhome.com/downloads/installManuals/ACC52i_O.pdf
    firstly, check out page 17, in the chart there, tells you that you want to clean your heat exchanger every ton OR monthly......not exactly end of season there....also, note, at the bottom of page 17, in BOLD type, then, look at where is says "Not properly cleaning your appliance on a regular basis will void your warranty".........I think what Harman ascertains as "regular" is the above rubric on page 17, not what the installer sez. Also, look on page 20, it shows you how to remove the exchanger covers and scrape the exchanger.......
    so, follow what the manual says, you should be fine!
    Good Luck!
  18. subsailor
    subsailor
    Winthrop, Maine
    FWIW JG I can feel a difference in the heat output of my stove toward the end of a week after cleaning my heat exchanger so I clean mine weekly. It only takes a few minutes.
    Lousyweather and wildwest like this.
  19. Lousyweather
    Lousyweather
    yup, its pretty shocking what a difference a good cleaning makes.....yea, it takes some time, but well worth it! Couldn't have said it better myself, Sub!
    badbob, wildwest and eatonpcat like this.
  20. slvrblkk
    slvrblkk
    Northampton, PA
    Oh jeez :rolleyes: ;)
