new husqvarna 562xp air filter concerns
Discussion in 'Chainsaws and Power Equipment' started by denny461, Dec 19, 2015.
  1. Ronaldo
    Ronaldo
    Ok, I've heard of some K&N oil that is a spray on, wasn't sure.
  2. clemsonfor
    It is spray on aerosol but I'm sure hes spraying it on the seams
  3. dennyf
    dennyf
    Florida
    The K&N air filter grease is very thick, not an oil and certainly not sprayed on; it is used only where the air cleaner connects to the air horn.
    Nixon and MasterMech like this.
  4. clemsonfor
    Oops sorry thought you were talking about then charge oil
  5. dennyf
    dennyf
    Florida
    Actually here is their description: K&N Sealing Grease 99-0704 provides an airtight fit around sealing surfaces on all types of air filter elements. It resists heat and will not melt or run off. K&N Sealing Grease is designed to ensure the filter stays sealed in rugged environments. It is not to be used on clamp-on filter elements. K&N Sealing Grease 99-0704 comes in a 6 ounce tube.
    • Prevents air leaks
    • Withstands high temperatures and will not run
    • Does not work for clamp-on applications
    • Comes in a squeeze tube
    Ronaldo, angelo c and MasterMech like this.
  6. pantelis
    pantelis
    Europe
    Yeah until the Husqvarna fix the problem of theirs flagship model................. the K&N company will make gold jobs
    :whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle::whistle:
  7. status1
    status1
    Australia
    Are your 550xp and 562xp still going strong after ingesting so much saw dust?
  8. clemsonfor
    If it was just mostly sawdust it wouldn't be terrible. But there would be dust with it which would be 50x more abrasive.
    Firewood Bandit and leoht like this.
